Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have an oil leak from my 2008 Escalade with 175k miles. It's on the driver's side rear of the valve cover. Initially I thought it was from the valve cover gasket but the cover looks wet as well. I attached a picture.
I would say it probably did. I've heard that the pcv is an issue on these and I had planned to replace that valve cover with the revised one that uses less oil.
Isn't the oil pressure sending unit in the middle of the valley of the engine in the rear?
Also a check engine light has come on. I haven't gotten the codes read but it's running fine.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
