Help connect map lights to dome lights
brucebly
Tennessee
Does anyone know how to go about connecting the dome lights to the map lights so they all come on when the doors are open but still independently turn the individual map lights on and off irrespective of the doors being open or closed and/or the position of the switch on the dome light assembly. This would be on a 2002 Tahoe.
Thumper8302
OKC, OK
i know what ur talkin bout man.. i did this in my 90 suburban.... now as far as the options ur wanting u would have to have some relays for sure but i have no idea on how u would have to hook them up.... in my burban i just had them all come on with opening the doors or from the interior switch
B
brucebly
Tennessee
I actually found a way to do it for less then a dollar. I took a wire and ran it from the positive side of the dome light to the positive side of the map light. Now when the door opens the map light comes on. The bad side of this is when the map light is turned on the dome light comes on. So I replaced the wire with a diode and now the map light does not turn the dome light on but the dome light turns the map light on.
Anthony
2004 Tahoe LT (MA)
Westen MA
Hmm, Ill do this after work today!
Thanks :Handshake:
oak510_tahoe
Urban Assault
hmm, on my 05 my two map lights come on with my dome lights whenever i open the door or unlock via the remote. They also work independently if needed. Was this feature added in on the later models?
Rivieraracing
Hey, can you post up a pic of the area that you put the diode and do you know which diode you used?
puckhead
CO
Nice! What kinda diode did you use? any one work?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
03
Rivieraracing
Bump for me!! I gotta get this mod done this week! Only wish that someone had a pic of what they did for their front map/dome lights!!
Brucebly, which dome light did you use as a power lead for the map lights?
PexoA78
