Help - Burning Oil
marinekills
Hello my 2001 Tahoe LT is burning oil. 1 quart every 1000 miles. I got the truck October 2012. I hardly drive it. It's my first truck so I wouldn't know if this is considered normal. 5.3 vortec :emotions122:
NathanJax
Vacation Nathan
Jax, Fl
no that's not normal...
some (more knowledgeable than me) will chime in soon...
chauncey0337
MLT, WA
I'm no mechanic but I can tell you this is not normal. I've heard, that for the age of the truck, about 1quart per 3k or each oil change is "normal". Are you sure it's not leaking? Someone with more insight will chime in soon.
Rivieraracing
Don't think this will completely solve your problem, but check your PCV valve and see if it is the type that has the ball in it and it rattles. If so, get yourself the updated one without the ball in the PCV!
pwtr02ss
Tennessee
^ that and try to run a little thicker oil, say 10w30 or so depending on the miles.
doylee4693
Tahoe User
New York
This has come up MANY times and people always say "its the motor" before checking there pcv valves. Most likely thats what it is if its a 2000-2002. Best of all theres and udated part for it just purchase the pcv valve that came on the 03-06 tahoes. Its cheap and easy to fix.
marinekills
marinekills
I just got the updated PCV valve and it doesnt fit. Help please
Screwd up 6
where did you get the PCV? Id go back to them and get the right one.
marinekills
marinekills
I got at my local Chevy dealer. Does anyone have the serial numbers for this part?
Screwd up 6
I just called on one actually. The manual in my glovebox for my 2002 with 5.3 says CV948C but the guy on the phone said I needed part# 12576460 which is the hose and PCV together.
From the looks on google/amazon CV948C looks like the old one you posted.
doylee4693
Tahoe User
New York
You are looking for part number cv4000c. Its 6.40 on amazon and one of the reviewers on the product said he had the same problem as you and the valve fixed it and also smoothed out his idle. Looks like the dealer gave you the wrong part. The old style that came on your truck is a spring loaded pcv valve while the updated one is called a "fixed orrifice pcv valve". After enough people starting complaining about there tahoes escalades silverados ect were having trouble with oil seeping past the spring loaded valve, they updated the part in 2004 to fix the issue.
Screwd up 6
I thought CV4000C is for FLEX Fuel...or does it not matter for the PCV valve
doylee4693
Tahoe User
New York
No it doesnt matter if its flex fuel. The cv4000c is the exact part I put on my 01 non flex fuel tahoe 6 months ago with no issues at all. Took 2 mins to install.
Screwd up 6
Good to know. Wonder what is the actual diff on the 2 parts since they reference one for flex one not for flex.
Screwd up 6
My Tahoe user manual states CV948C for 2002. The manual doesn't state anything for Flex from what I can see. WHen I looked online at rockauto and many other sites they reference Cv4000C for Flex fuels on 2002 and regular or flex for 2003. I don't know what the difference is, that's why I am curious.
I do know the CV948C looks like the original posters PVC that he pulled.
CV4000C - 12572717
CV948C - 25179136
The only visual diff I can see so far is the CV948C is brownish color and the CV4000C is shiney/polished
Ok..found this on another site. The one you reference is a newer style (better) with the out the checkvalve.
***EDIT***
_________________________________________________________________________
Document ID# 901494
2001 Chevrolet Chevy K Silverado - 4WD
Subject: Higher Than Expected Engine Oil Consumption (Replace PCV Valve) #01-06-01-029B - (07/19/2002)
Models: 2002 Chevrolet Avalanche
1999-2002 Chevrolet Silverado, Suburban, Tahoe Models
2002 Cadillac Escalade, Escalade EXT
1999-2002 GMC Denali, Sierra, Suburban, Yukon Models
with 4.8L, 5.3L or 6.0L Engine (VINs V, T, N, U -- RPOs LR4, LM7, LQ9, LQ4)
This bulletin is being revised to clarify the parts information. Please discard Corporate Bulletin Number 01-06-01-029A (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on higher than expected engine oil consumption. They may further comment on consumption in the range of 3,200 km (2,000 mi) or less per quart (0.946 liter) of oil under normal driving conditions.
Cause
The condition may be due to the positive crankcase ventilation (PCV) valve flow rate under certain engine operating conditions.
Correction
Verify that the oil consumption is not the result of an oil leak or other engine concern.
The dealer should perform an oil consumption test. The vehicle should have accumulated over 6,450 km (4,000 mi) before establishing the oil consumption rate. Reference Corporate Bulletin Number 01-06-01-011, Information on Engine Oil Consumption Guideline, for details.
Remove the PCV valve and inspect the hose going to the intake manifold for signs of excessive oil being present.
If excessive oil is present in the PCV hose, replace the PCV valve (Type 948C) (2) with a new-style fixed orifice PCV valve, GM P/N 12572717(1). See the illustration below.
PCV Valve Identification
(1) New style fixed orifice PCV Valve
(2) Spring and plunger style PCV Valve (Type 948-C)
Important: The new style fixed orifice PCV valve contains no moving parts, and does not rattle when shaken.
If the vehicle has an orifice style PCV valve, investigate other causes for high oil consumption.
Parts Information
Part Number
Description
Qty
12572717
Valve, PCV
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J6000
Valve, PCV - Replace
Use published labor operation time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
6point2lovelifers
