heated seat problem
hollywood_716
new york
Heated seat on driver side shuts right off. Pass side works great until you turn driver side on. Changed the elements and still does the same thing. Please help. Any ideas or solutions would be greatly appreciated. Thanks
Mildly
Washington
Did you change the seat and back elements or just one of them? There is a TSB on that! I will try to find it and let you know. I have the same issue in my 03 yukon slt.
hollywood_716
hollywood_716
new york
Changed back and bottom. Still the same. Hit the button and it will kick off after a couple of seconds. The passenger seat works great unless I turn driver side on when it kick off it shuts passenger off
---------- Post added at 07:00 PM ---------- Previous post was at 06:59 PM ----------
And the elements I took out didn't look like they were bad
a4edwin
ny
has anyone everfound the solution to this problem? mine does the same thing. and i've seen other posts about the same topic. never a solution though
04SS99Denali
NY
check the harness? make sure the harness isnt fried up and everythings plugged in
a4edwin
ny
my harness is good and everything's plugged in still the same problem.
a4edwin
ny
bump it's getting cold out and it sucks that my pass one will work fine till i try my side then they shut off
Sullen
North Mississippi
On my old 03 and 05 they both did it, I honestly think its one of those 'As soon as you hit the 130,000 - 150,000 mile range it stops working to try and get you to bring it to the dealership' one of those secrets they don't want you to know about, kinda like on the 90s models the check engine light is almost guaranteed to come on around that 170,000-200,000 mile mark.
Mr.Jack
Norway
I spoke with my local dealer/workshop the other day. And he told me in 90% of the cases where the seatheater is not working, it is the pad.
So I guess I will be ordering a pair of those pads soon.
http://www.youtube.com/watch?v=gsFzi1a5qoI
---------- Post added at 06:00 AM ---------- Previous post was at 05:58 AM ----------
Did you change pads on both the driver and passenger seat?
DenaliAK
Colder than you
Alaska
Also have this exact issue. I don't want to spend the time and money replacing things if it doesn't solve the problem, so someone update this if you find the solution. It's a pisser when it's -15 out and I'm spoiled and can't have my heated seats....lol.
DenaliAK
Colder than you
Alaska
Anyone have a part # or link to replacement pads/elements? My Google-fu is a fail this morning.
georgebuhr
Paid I get time I may tackle that this week. Mine is opposite. Drivers side works great til u turn passenger side on, then both kick off. Passenger side doesn't work at all; kicks off after three seconds. Not so sure it's the pad on this particular case.
johnsonwillie199
