Heads up Display is Crooked
mobe1957
I noticed that the heads up display in our new 2019 Yukon Denali was crooked in relation to the road.
This was driving me crazy and I could find no information on how to fix it. I even considered taking the dash apart to see if I could move it.
Then this week while driving through Kansas on our way to Colorado I was messing around with the settings on the right side of the steering wheel and found an adjustment for the tilt of the heads up display!
In the center screen between the speedo and tach, go to a setting that has a left and right arrow on either side of the display, ( in my case I was on the screen that has the total miles left to empty, instant mpg and V8 or V4 info).
Press the left arrow on the right side of the steering wheel,
Scroll to the gear symbol
press the check mark
scroll up or down until you see "heads up display"
press the check mark,
use the up and down arrows to tilt the heads up display to your desired tilt
press the check mark to confirm.
DONE!
AdrienR
