headlights don't work off switch
02YukonD
U said 2 light sensors.. I thought these trucks only had the one light sensor (ambient).
El Capitan
Senior Texas Member
Grapevine, TX
So pictured is what I have on my 01 Tahoe, apparently one is a Temperature Sunload Sensor (GM Part# 15740822) and one is a Ambient Light Sensor (GM Part# 12450120) both sensors seem identical, except for the writing on the sensor itself. Now the problem I have is I do not know which sensor goes on which side, and last time I replaced them used part number 12450120 for both. Will post update as soon as possible.
02YukonD
Oh OK... I only have the ambient light sensor.. I have to pull my my dashboard apart and check
El Capitan
Senior Texas Member
Grapevine, TX
I have another thought anyone feel free to chime in if I am right or wrong, if the day time running lights are burnt out (both) would it cause the headlamps to come on? I have 2 new pigtails from GM for them I figure I will replace the pigtails and bulbs and see if that may be the issue.
02YukonD
I put a new ac delco headlight switch in and solved the instrument cluster lighting issue but it's still not operating the head lights.. imma go out on a limb.. but I'm driving my truck without the factory key with the chip in it. I have a regular copy of the ignition key without the chip. Maybe the computer isn't reading a chip and causing some of those problems to occur.. do that sound about rite? a could that be the issue?
El Capitan
Senior Texas Member
Grapevine, TX
From what I understand if you have a chipped key your truck shouldn't start without a programmed chip.
02YukonD
U right I looked it up.. imma really have to pull the dashboard apart soon. My fog light not working also. Imma check the fuse and wiring with my test light
El Capitan
Senior Texas Member
Grapevine, TX
Check fuses first, idk if there is a relay for fogs, was your truck factory equipped with fog lights?
02YukonD
OK thx for the advice.. I'll start at the fuse and work my way back
CKendrick
