Headlight switch & 4WD switch illumination
NGAneer
NWGA
Tried searching and didn't find an answer...
My headlight switch does not illuminate, though it used to. The 4WD switch illuminates but in a warm white, incandescent color different from the greenish/blue of the rest of the dash/radio. Is there a way to replace the lights in the switches or does the whole switch have to be replaced? Seems like the warm white light had to get there somehow. Thanks in advance.
agupta3224
I am not sure if this will help anymore. I did some bulb changes in my Acura and had to peel off some labels to find the bulbs. In your case, it looks like, once you pull the switch assembly off you could probably disassemble the switch. There looks like a pushed in panel in the back, under the UPC bar code label. See if you can pry it loose and find the bulb inside.
Meccanoble
Georgia
My headlight switch doesnt illuminate either. Interested in the fix as well. My AWD is white like yours too.
clemson01
Yeah same here, I've had my tahoe for 3 yrs and it never worked. Curious to know the fix
Sent from my SM-N910V using Tapatalk
AdrienR
