Headers/ypipe question
Kingmarchil
Hello all i have a '16 yukon denali with magnaflow 3.5" catback and volant CAI 380 rwhp atm wanting to push over 400+ rwhp
Im looking to install kooks headers (28602401) and catted ypipes (28613200) but i want to know will it fit or the 8speed ypipe has different placement?
And when i search for headers they're mostly for silverado/sierra.. are all trucks and suv 6 or 8 speed the same down under and all ypipes fit?
NORCAL SS
SUV SUSPENSION GURU
i have 1 7/8 arh headers and non catted y pipe and installed and sold many. I dont use kooks anymore the arh has better clearances. PM me My truck makes 565/573 on pump 91 gas and 7.5 psi on whippple 2.9
2016YUKONSLT
Can you get the ARH for a 5.3L?
Jorgez28
Are there any gains with a header and a y pipe and a stock exhaust? Do you need a tune after a header install?
Kingmarchil
Kingmarchil
The new gen exhaust manifold are high flow and will not net that much hp, the real restriction lies in the ypipe which is where you get the most hp gains but since you'll upgrade to an aftermarket ypipe might aswell get the headers
Ive seen 20-25 rwhp gains with headers+ypipe.
And yes you need the tune, otherwise your car will run rich and get worse mpg and possibly less hp than stock.
NORCAL SS
SUV SUSPENSION GURU
i gained a solid 25-30 rwhp on my escalade with the headers. no cats.
i have the full magnaflow 3.5 cat back also
2016YUKONSLT
20-25rwhp for headers/y-pipe seems to be pretty normal. I remember picking up 15-20 rwhp with shorties and around 30 with long tubes on my f-bodies.
How much of a gain would you see with a y-pipe though, if it is the restrictive part of the exhaust?
2016YUKONSLT
Just getting rid of the cats in general will yield hp(better flow), but he said the y-pipe was restrictive. Is it crimped, flattened, not mandrel bent?
NORCAL SS
SUV SUSPENSION GURU
if you can have a shop do a 3 inch y pipe and mate it to a cat back exhaust that will flow very well.
Kingmarchil
Kingmarchil
Its flattened to not hang lower than the underbody, take a look under your car and you'll 100% understand.
2016YUKONSLT
How much does ARE headers and ypipe kit cost for 5.3l 2016 yukon?
NORCAL SS
SUV SUSPENSION GURU
Do American racing headers no cats. Period
koomie98
