Going up to 20s
jcevans7
Friendswood, TX
I have a 2003 denali wanted to know if I could put on 20s. As long as the bolt pattern is correct it should be good? Right.
The speedo will have to be reprogrammed anything else I should know or look into.
Sent from my SM-N910T using Tapatalk
Pockets
West Ga
Yes... just when you go up in wheel size make sure your overall tire size is the same.
southboundchicken
Jacksonville fl.
You shouldnt need to reprogram the speedo if staying with tires with same diameter even if they were taller it would only effect the speedo by 1-2 mph, try gauging it with a gps you'll see there is little difference
jcevans7
jcevans7
Friendswood, TX
Put them on today same size no issues will get a pic or 2
jcevans7
jcevans7
Friendswood, TX
Same size in over all length. Maybe actually faster proven no scientific data.
ezdaar
Chat Troll
Redneck central, Aka Houston
read the same OAL, im previous posts.
Was directed more to the extra weight of the 20's.
Mine are heavy as hell. almost need a 10 ton crane to move them around.
TheAutumnWind
Which 20's do you have Doug? OEM?
Drewphil
