GM OEM eFans vs Flex-a-lite question
Karlus
I have an 03 Tahoe.
I'm wanting to switch the clutch fan out for electric. I've seen info for using the OEM Silverado dual fan and turning the fan on in the computer. Understood.
What is the difference between these fans and the Flex-a-lite fans (besides cost)? My undertanding is the Flex-a-lite will draw 28 amps at full tilt boogie. Means new hi-po alternator.
Are the OEMs less powerful? Anyone know the differences?
Thanks!
I have an 03 Tahoe.
Thanks!
Try and compare wattage too. On the later generation, we have 500 watt fan motors and 700 watt fan motors.
Thirty years ago I put a Black Magic Flex-A-Lite fan on one of my cars and it kept those two race cars cool for many years. Having said that, my preference is almost always towards OEM parts.
My short and simple reply is that OEM fans are designed to work with the rest of the OEM system (the physical fitment to the rad, alternator's output, PCM control, etc.) and do so for 100,000+ miles. Good aftermarket fans are designed to last "a while" (at least, longer than the competitor), but are only warranted for 90 days, maybe a year, maybe two years. The OEM fans are guaranteed to fit and be the easiest to implement.
Karlus
Karlus
Agreed. So reading between the lines: the stock alternator will work with the OEM fans and that means less amp draw but less "performance."
The aftermarket fans seemed a bit high at 27 amp draw and I would imagine are for performance or forced induction engines where extra power is required.
Karlus
Karlus
I am also wondering about the hassle of using the PCM to control the fans vs just using a temperature sensor near the inlet side of the radiator to control the fan speed. I don't have a programmer yet, and would like to avoid buying the hptune right now.
NoReverseYukon
NE Wisconsin
Just a quick search shows that 2003 Tahoes had both 105 amp and 145 amp alternators. I suspect you'll need the 145 amp if you want to install e-fans.
I got lucky - found the fan,wiring harness, and HD alternator on same vehicle in salvage yard. Haven't gotten around to installing them yet.
BG1988
good choice with the oem the op should go with oem
iddqd
San Francisco, Comifornia, USSA
This is true not just for fans, but for everything aftermarket :)
With some exceptions of course, like OEM suppliers for example
I'd aim for an AD244 (180A). But, yes, a stock high-output alt instead of the stock standard (105A) alt.
"Less performance"? Depends on how you look at it. In this case, less is more. An aftermarket fan is gonna be designed to meet and exceed most needs so a given fan can be used across a wide spectrum of applications. It's also intended to cover those modified applications where an OEM fan is inadequate. If it's too much for a particular setup, it'll simply be ran for shorter amounts of time or be slowed down if it's on that kind of controller. It'll still be pulling excess amperage, but that's the nature and it'll have to be addressed elsewhere. OEM will select a comparatively less powerful fan because anything more is excess and just presenting extra, unnecessary load on the charging system.
PCM-controlled is best, but a sensor that directly reads the coolant temp just like the factory sensor is second best. There are aftermarket sensors that screw into unused/blocked-off ports in the coolant jackets, just like the factory one in the cylinder head. The radiator fin probes are 'okay' if you have it on an adjustable controller since that can be adjusted for any inaccuracies in temperature reading.
ivin74
05 NBS Nali
Htown, Texas
I have an 03 Tahoe.
Thanks!
I put the flexlite fans on my 03 Silverado SS and they worked great, the only thing I didn"t like was that they were freaking loud. The only issued I ran into was the wiring got hot and melted the fuse that came with the fans. I replaced the fuse with one of those they use for amplifiers. This was back in 2007, flexlite might have already fixed that flaw.
https://www.amazon.com/Rockford-Fos...ocphy=1026681&hvtargid=pla-571240275103&psc=1
Karlus
Karlus
Im just concerned about messing with the PCM wiring.
You are knowledgeable and being new I respect that greatly. Do you have a recommendation on a radiator probe and controller? Im happy to do my own research, but if someone had success I would be interested.
Thanks so much
Thanks so much
My experience with a controller was with the Ford Taurus fan I had on my S10. I used a Flex-A-Lite #31165 Variable Speed Controller. I went with this one because it started the fan at 60% power then ramped up the power/speed as needed (if needed) to greatly reduce the load on the charging system. It also has a 45-amp capacity. I had it adjusted to turn the fan on at just a hair under 210, going by the dash gauge. I don't know if it wasn't available then or I just didn't know about it, but they have a temperature sensor version, part #31163. I definitely would've gotten that one. The probe style worked fine for me, but there are still variables that can affect it's readings. I'd get the thread-in sensor style and screw the sensor into the plugged-off port on the passenger head.
I have no experience with it, but they have a much cheaper controller, #31147, that's just a simple adjustable controller with a probe sensor and 20 amp capacity. This one should definitely be used to trigger a high-amp relay because a single fan sufficient enough for a 5.3 will pull much more than that. You'd also tap the relay into the A/C compressor clutch wire (use a diode!) so it triggers the fan when the A/C is on. Next up from that one, and simplifying things, is the #31149. It has a 40 amp capacity and an A/C trigger input. I don't know what amperage an OEM fan draws, so I can't say if this one has enough ampacity.
Karlus
Karlus
Awesome. I love these solutions. Let me see what I can pull together
There’s a tech section thread on this with a walkthrough for using the pcm and a lot of information. There’s a couple pins to install in the PCM harness but it’s detailed in the thread. You also need to have a tuner turn on the function. It’s not hard, but if you go that route I suggest having the pins turned on before you do the mod so it’s ready to go.
JasonW4141
