Jason in DLH
Cheeseburger and Fries
I thought this might help someone out in the future if they can’t find torque specs for a nut/bolt...
Looks like those #s correspond to grade 5 on the lower end and grade 8 on the high side.
Jason- you are teachin them the wong way! FSM has a torque for nearly everything, and a better generic chart showing hardness marks too!
I use this app a lot.
https://apps.apple.com/us/app/iengineer/id369825047
Sounds good. If I remember correctly, I had to pay a couple bucks to get the metric stuff, but it was worth it for me as a quick reference when I was designing equipment.Took a quick look at that and downloaded it immediately! I think it’s great it has lubricated torque specs as I’m always wondering about this.
I completely agree that you should follow factory torque specs.For me it's a trust thing, along with common sense/experience. Was just working on a differential, and the pinion torque was listed in the factory manual at 390-425 ft/lbs. 25 mm shaft, fine thread 1.75, 8-9 threads total in nut about 5/16 inch,with nut using a pin type 4 slot socket same as a 4x4 old style hub nut. No way that shaft/nut could handle that, or the socket! Still havn't gotten an official reply back. I already know the answer. Piss poor design, no lock other than the flange on the nut to be staked after torque into a fine 26 spline. Guaranteed to come apart sooner or later. So they upped the torque. Should be a mandatory recall.I'll bet they sell alot of parts, two or three times. Pinion shaft is $1400. Also, since it is a pinion, what about the bearings preload? I think they just moved the decimal on the torque spec. Not enough threads on pinion to change to a better design.
But back to TRUST, some copy/paste GoogAppl app idiot like above manager thats trying to save his skin or an app designer that has people driving into lakes following his directions. Which do you trust? I'll stick to factory, they have warranty/recall. And guys like me bitchin.
