Fuel pump?
yukondoit
Stay Classy
Flagstaff, AZ
Would the fuel gauge be working if the fuel pump is out? Pulled up to a stop light, light turned green, yukon shut off. Engine turns over, it has half a tank of gas, but won't start. Any help would be appreciated, I'm currently broke down in north phx.... Anyone in the phx area?
chauncey0337
MLT, WA
Yes, fuel gauge should work even if fuel pump is out. Sending unit is next to pump but it's a separate mechanism. Try to see if you have a pressure valve on fuel line under hood to check for pressure. Watch out for squirting gasoline.
bankswood
sometimes you can hit the tank a few times with a rubber mallet and it will energize the pump so you can drive it home.
Rivieraracing
That's exactly how mine went out months ago, rolled up to a stop sign next to my house, as soon as I pressed the gas it died on the spot!! After that, it turned over fine but sounded like it wanted to kinda start but it wouldn't, kinda like flooding a carb'ed motor!!
And yes, my gas gauge worked, like mentioned it's a separate item attached to the fuel pump!
yukondoit
yukondoit
Stay Classy
Flagstaff, AZ
Well I got a tow to a friends place... Now I have to figure out what the problem is. Check engine light is on, p0178 comes up. Which is basically the flex fuel sensor. Would that be a possible cause of it not starting? Would the sending unit cause it not to run also?
chauncey0337
MLT, WA
I don't know much about flex but a bad sending unit shouldn't keep the truck from running.
bankswood
you can check the fuel relay. it is in the fuse box under the hood. swap the relays around to see if it is a bad relay. probably not. These trucks have a history of bad fuel pumps. Don't go to the Stealer for the repair. He will quote $800-$1000. I bought a fuel pump assembly from Advance Auto for $275 and had a mobile mechanic install it for $175. The mechanic had done so many it was second nature to him. I helped him install it so I could learn how to do it. It's not nearly as hard as it sounds.
yukondoit
yukondoit
Stay Classy
Flagstaff, AZ
I'm here in phx for work, up to friday. Stressing big time over this, plus I have no tools with me, so me doing my own install is kinda out of the question.
carman2197
