89RagTopRS
- Joined
- Apr 29, 2017
- Posts
- 3
- Reaction score
- 0
Okay, here's the specifications: 2002 GMC Yukon XL 1500 4wd 5.3L Flex Fuel. 182k miles. Spotty to nonexistent service history outside of my own. Brand new transmission with shift kit, valve body and all the other things GM should have done factory, flex fuel bypass since it will never see E85 and the sensor is bad. Engine code is downdraft O2 sensor failed (bad wire I'm still tracing as the sensor is new). The price was right and I knew what I had even though I haven't found all of the problems yet.
The truck has suddenly been tasked with doing 70 mile hauls every 3 days or so with some weight and no towing. I personally have had zero issues with it. I have thousands of miles on it. I was a passenger in the truck the first time it stalled out seemingly out of nowhere less than 2 miles from our destination 7 days ago. I know it is not a ghost issue as I've witnessed it. I drove it back 2 days later without issue. The other drivers often hit 3000+ rpm at acceleration where I almost never exceed 2000-2500. The highway doesn't count as far as top speed rpm. There has been issues where it took 2-5 minutes to get it restarted and an issue where the throttle had to be to the floor to get it restarted.
I'm 60+ miles away and the crew on site is going to change the fuel filter that is of unknown condition or mileage. They have no way to test fuel pressure on site without me and I'm 4 days away at minimum. I'm going to have a fuel pump shipped to site. What else part wise besides my trailer would you recommend as I'd just assume tow it back with my Sierra than pay $500+ to bring it back with a towing company?
I'm just learning all the issues with the Vortec LS engines and that generation truck series as I'm familiar with the older models and the old Nissan Z24 engines. I'm leaning towards pump first and regulator second, but what are the odds it's one of fuel injectors is stuck open?
