Front & Rear Heater Core Flush
cmatt
I’m changing fluids in my new to me 135k mile 2012 Suburban and the coolant is next. While doing so, I thought it might make sense to flush both heater cores. I haven’t seen much info on flushing the rear one. Is there anything I need to be mindful of?
Derick
Indy Suburbs
Curious to know too. I plan on doing a cooling system hardening myself within a few months. I know I'm going to backwash the heater core.. But curious to hear the word on the rear unit as well.
St. Louis
I've never really heard of anyone having problems with a clogged rear heater core. I guess it wouldn't hurt anything to do it.
I had a problem with my 2001 about a year ago with the front not putting out heat and I back flushed it and it fixed it. Never had a problem with the rear. The truck has 215k on it and original cores
Moderator
People's Republic of Colorado
Just watch the water pressure, keep it fairly low to start with until you are sure you have good flow. Full house water pressure (60+ psi) could be too much for the system (15 psi), since water doesn't compress easily and that can be ******* connections. Have an extra short hose to redirect the outflow.
St. Louis
Good point.
When I did mine, I have a ball valve type of fitting on the end of my garden hose and I only cracked it open a bit, not even half way.
Looks like this, Lowes, Home Depot, etc about $7
Tupapi
