Front hitch mount
5strmtrp
Any of you get a front hitch. Punt on the front of their trucks?
I have the go rhino push bar on my truck and just purchased a 12000 lb winch for the truck. Mostly for pulling stuff out of barns etc but also for those “just in case” moments that have happened in the past.
I’m looking to see if anybody that has a front hitch mount will work and bolt in to the same area as the push bar without interfering with each other.
I’ve seen a few out there, but they also say not with the Z71 package which oddly enough my truck has.
Feedback welcome. Moron statements included!!!
Sparksalot
Bastrop County, Texas
I think the Z71 limitation probably has to do with the metal engine skid plate.
I have been considering mounting a universal winch mount between the uprights of my pushbar to achieve what you’re thinking about.
5strmtrp
5strmtrp
The skid plate is the reason why a lot of sites say it’s not compatible with the z71’s. However some of the hitches do not even come near the skid plate. Curt hitches is one of them.
My ? is. The approach angle with the hitch protruding out past the bumper I’m told it limits the approach angles. Anyone here that can say it’s a pita or nahh don’t worry about it.
As far as attaching it to my Go rhino pushbar… it’s not fitting anyplace but up high above the bumper. I would need to get a stronger cross plate. It would need a significant cross bracing to hold it in place and not rip off the pushbar or bend it up. I guess anything is possible.
Sparksalot
If I go the pushbar route, I’d go low, down near the frame brackets, otherwise you’re spot on with the leverage being out of whack.
the pushbar does limit my approach angle, probably much more than a front hitch would.
01whitewhale
This is my z71 with a 2" leveling kit running the Curt front hitch. I wouldn't install a hitch if I wasn't leveled, the angles wouldn't be very usable. I do scrape the Giants logo on the hitch when I'm roaming the mountains of southern Utah but that's only when I stray from the dirt trails and I'm making my own roads. I did have to notch the bumper just a bit for the hitch to fit, but that was it.
SURF FISH MAN
N N J
My Pavement Plowing Curt hitch has ripped more than one concrete parking lot stop out by it's rebar!
Don't brake too hard for Speed Bumps either, you might bite your tongue.
JasonW4141
