Front End Noise
GDEG
I have a 1999 4wd 4-door and am getting a popping-clunking noise at low speed whenever I hit a bump out of the front end, driver side. It does not make the noise at highway speed. It may be louder or occur more often when making a left turn. It has new shocks and I thought that they might be loose and I went ahead and tightened them up. That seemed to stop the noise but it is back and everything is tight. Any ideas?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You have loose hardware or bushings on you front end components. But on turns consistance with wheel speed clicking or clunking noise can be a worn out cv joint at the outerwheel. If you can get the vehicle up shake all the components real hard to find play in the parts.
Drewphil
