Front end clunk
quick66ss
Columbus Ohio
I have 20,000 miles on my Pedders kit and have noticed a clunk when I go from one direction to the other. For example if I drive forward a few feet and stop I get the clunk. If I then go in reverse for a few feet and stop I get the same clunk. I have been through the suspsion and everyhting looks good. I thought it might be the brake pads shifting but its to loud in my opinion. So does anyone have any ideas? it sounds like its cominmg from the front end.
Modded
That Guy
Make sure your brake calipers (120 ft. lbs) and sway bar end links (60 ft. lbs) are tight, most of the time that is the problem.
quick66ss
quick66ss
Columbus Ohio
Modded
I will check as I did not use anything more than a wrench to tighten both up.
JamesinAbilene
