kaoticlife
a couple weeks ago I went to upull and pay junk yard and found this set of switch looking things attached to a swapped caprice and asked about them here and we couldnt figure them out. Well after a little research I found that these are indeed klixon 50 amp each thermal overload protectors and they are very heavy duty! heres the pic of what I have.
and here is what a website has to say about them. the two I have are 6766-19-50amp these things are $145.00 each.
http://www.carbonbrush.com/klixon6766.htm
Klixon 6766-19 Series 35 to 150 Amp Commercial, Switchable Thermal Breakers Series Specification Sheets The 6766-19 is a manually switchable ignition protected thermal circuit breaker that is ideally suited for rugged applications. This device is commonly used where a robust, weatherproof switchable breaker is required. Applications include accessory and equipment protection for heavy trucks, construction equipment, off–road vehicles, and marine equipment. Mounting holes are 2.406"(61mm center to center)
what should I use them for? work with my dual battery setup or not? ideas? anybody need one if I dont use em both?
