Fog lights have never worked.... Input please
solored
canada
Ever since I have owned my truck, my fog ligths have never worked. The odd time one will come on...And it seems that the fog light switch dont work either. I know the bulbs are new, tried to do HID's, but didnt matter.
I have a 2002 GMC Yukon, I know where the switch is, and it has the rear window wiper control on it to, its all one unit. I have heard that these have bad grounds, but if that was the case the rear window control wouldnt work?
I want to HID's, and the HI-6 Mod, but I need to some how figure this out.
Any ideas would be greatly apperciative!
Thanks,
-Danny
chip
Cincinnati
If you know the switch doesn't work, try replacing that first. The fogs are on their own circuit.
S
solored
canada
Perfect, I was thinking that if the rear window wipers worked, then so should the fogs.. But I will replace that for sure. And hopefully that will fix the problem..
I havent checked for power to the lights, but every now and then one will randomly come on..
chip
Cincinnati
I would definitely check power first, but that sounds like your problem.
S
solored
canada
Perfect! Will be checking that when I get home.. 36 day hitch, wont be home for a bit yet haha
Thank you very much for the input!!
oakrdrs187
Coachella,CA
You can save yourself the cash on the fog switch and get a relay harness when you go HID and tap your trigger wire ( going to fog relay on the harness) to low beam positive, and then you will just need 4HI MOD since your fogs will remain on with the already lit lows.
Physh1
Check the relay for the fogs...if you're getting them on once in a while the relay may be bad.
Cameron
S
solored
canada
I might just change it all out to new fresh parts, I dont imagine relay and switches been to much.
Thanks again guys!
johnsonwillie199
