Fog Light addition
1badc4
1badc4
Wiring sux! Good luck with the vette. Sometimes, what I've done in the past--if the harness is a pita to pull, I'd just cut off all the connectors, splice them onto new wire, run it where it needed to go, and be done with it.
EDIT--What are you doing with the vette? Sound system?
Pioneer double din
Pioneer 4 channel amp
JBL components front with tweeters in A pillars
JBL 6x9 2 way in rear
Bazooka 8" powered sub
and repair LED part of dash while apart. it intermittently goes blank
flush mounted usb/3.5mm outlet in dash
IMG_20190524_142152237.jpg IMG_20190613_153552914.jpg IMG_20190424_210534472.jpg IMG_20190613_160254561.jpg IMG_20190505_175926288.jpg
mountie
1badC4...... My ( late) friend held the closed course speed record in one of his 'Vettes.
A black C4... He did it at Talladega Speedway.
I don't remember the average speed... He had a Traco engine in it.
It was a beast !!
1badc4
1badc4
It was a beast !!
Mine is mostly stock LT1
Lloyd Elliot custom ground Lunati cam
CC hardened pushrods
Lunati Voodoo roller rockers
Lunati double 345# valve springs
****** super comp. ceramic coated long tube headers
full Borla stainless exhaust
3.54 rear gears
Protorque 2800 stall converter
SLP Claw Cold air intake
tweaked transmission shift
does the 1320 in 12.63@108mph with 1.7 60' personal best.
sorry to hear Late friend
Heather vette.jpg FB_IMG_1537406137600.jpg IMG_20180514_145219550.jpg FB_IMG_1537134054869.jpg IMG_20190424_211832528.jpg
mountie
A pic of my friend's Black GS 80... He averaged 180mph at Taladega.....
The red one..... Years ago an old lady was selling her home in Burbank, Ca. She had an apartment above a garage. Back in 1976 an Army Vet suddenly moved away, without a trace. He left the "Chevrolet" in the garage, where it sat until the lady was selling her home and she wanted to get the car removed. ( 1988? )
A friend of his, told Him about a "Chevrolet" in a garage, and if he would check it out. He went there to his AMAZEMENT, IT WAS THIS "Chevrolet" covered in the garage. Original.... He felt bad....He only had $300.00 cash in his wallet. She sold him the car......
He cleaned it up.... kept it...
Of all people to get this garage find, it was him !!
( Dick Guldstrand " Mr. Corvette" )
((( here I go again..... " Off Topic" )))
Guldstrand GS Taladega.JPG Guldstrand garage find ext.JPG Guldstrand garage find Int.JPG
adriver
If you're not the original owner, you could always verify RPO codes to make sure the pin is not already on. I THINK the code you are looking for is C85, (but if you really want to know, then you should check them all http://www.cadillacfaq.com/rpo/ ). Original owner could have hit something and had to replace, or didn't like them, whatever... More than likely they would have just left the harness and switch in place though. Still a chance it got damaged too, sold, or maybe they even wanted to swap it to their other vehicle. Just covering all possibilities.
DougAMiller
Colorado
According to my RPO list it's T96.
1badc4
1badc4
View attachment 226128 View attachment 226129 View attachment 226130
That's Awesome
TysonTrost
St. Louis
That’s what I would do. Simple job using an aftermarket switch.
I agree, i changed out my yukons Fogs for some 6in bars, the factory switch is more of a button and the lights will come off with your brights. Id run your hot from the fuse box accessory nice and easy then put in a 10amp fuse.
willb
