Floor Jack Recommendations
EddieC
So, the last time I wrote about my NAPA Blue Beast floor jack was 2024 when I estimated it's age at 35 years old and it still lives with more TLC but, as previously suggested by members, I am starting the search for a replacement.
My use is (residential) for the Tahoe and a Subaru, but more and more the Tahoe, so a significant lift height is in order.
The appropriate capacity might be in the 3 Ton area, plus or minus. I presume over sizing might increase lifespan if not used to full capacity.
I would appreciate any brand/model suggestions that might last at least 10 years.
Also, a serviceable cylinder might be a good thing because I could never find parts for my old Beast but I luckily had good luck with. The local hydraulics warehouse couldn't match up seals to have on hand.
I realize that it's probably going to have to be an import but which country(s) and companies are better, perhaps middle of the pack?
I have to laugh at Harbor Freight jacks having a 90 day warranty that is far from confidence inspiring.
Jacks are too heavy to be buying disposable ones at my stage of life.
15burban
Wisconsin
I have a 3 ton harbor freight Daytona out in my shed/shop that's about 5-6 years old. Lifts my 3/4 ton ram without problems. In the attached garage I have an older (20 years give or take a year or 2) harbor freight 2 or 2.5 ton jack. I forget the brand but it still works great. Lifts the wife's suburban and my work car. Neither jacks have needed any maintenance except for a pump or 2 of grease in the old jack and the newer one has a sticky "cylinder" or whatever its called, under the jack handle every once in awhile. A little lube solves that.
Personally I'd worry more about jack stands then jacks. As that's what should be supporting the weight while your working on and/or underneath.
EddieC
EddieC
The only thing I worry about a jack is it's becoming scrap metal due to lack of repair parts. I don't get any part of me under a vehicle when the jack is the primary support. I do sometimes use the jack as a secondary safety backup when the jack stands are in place.
Jack stands are (AUSCO) Auto Specialties Mfg Co jack stands that I have had for longer than I can remember. They are made of structural steel angles and plates, with beautiful welds and double prawls. They have the name of the town (St Joseph) stamped into the steel and it matches the information labels. USA workmanship.
I am awaiting a pair of ESCO 3 ton tripod stands coming soon. Hoping that they are half as nice as the Auto Specialties.
Now for a matching jack.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Unfortunately jacks that are made today aren’t made to be repaired or last very long. Even if you take good care of them. Jack stands are even worse.
As I’ve stated on this forum before… Jack the vehicle to a little higher than you need and put a few solid concrete blocks with soft wood on top, then lower the vehicle onto the wood, releasing the load/pressure on the Jack. That’s all the support you’ll need and it’s stable. The blocks and wood are called cribbing and it is the best/safest way to support a vehicle while you work on it.
Also, you need to make sure the vehicle is level and you lower it on its support points. Aloha!
EddieC
EddieC
Now that you mention that, I have a very large oak tree on the ground waiting to cut to firewood lengths that could donate a few pieces for duty.
Solid concrete blocks are beyond my weight limit anymore.
In any case, I always use double supports.
I have to laugh that you mentioned cribbing. I had done several design jobs for a local sizable contractor and one old timer project manager would always throw that out as a solution......"Can't we use timber cribbing?" Apparently he had a pile of timbers used to support crane outriggers in the yard so he always threw it out there in the most inappropriate situations. Eventually the proposal got named after him
EddieC
EddieC
I have the the 4 ton Daytona jack (Hulk Green) from Harbor Freight that throws my Tahoe around like it's rag doll. Love it.
I noticed that many of their "Rapid" models have double plungers but not the "Super Duty" 3 ton Rapid model.
Any idea what the difference is?
bill1013
Waianae, Hawaii
We “Old Timers” have plenty of knowledge and know how to pass on if you’re open to sit and listen. Our stories have a purpose too… but listen closely.
Also, Simplex and Enerpac are hydraulic and air bag providers. They sell equipment that is reparable. Unlike many of the floor jacks that have been mentioned in this thread. Aloha!
EddieC
EddieC
Ha, you're addressing an "old timer". The older I get the less I know.
bill1013
Waianae, Hawaii
Not meant for you. Just a general statement. Having taught many apprentices that just didn’t have the patience to STFU and listen…Very frustrating as they thought their basic training taught them everything they would ever need to do the job. And that was even after I would tell them what my trainers told me…”Everything you’ve learned…forget it! The real world doesn’t work like that!”
Many minds solves problems better than just one. Experience means a lot, so learn from it. Teamwork makes the Dream work. Aloha!
DaveO9
Vancouver, WA
I have a 3-ton Arcan that I bought from Costco - I'm pretty happy with it. They have both steel and aluminum versions. I have the steel one - cheaper, and I don't pick it up that often so no need for the weight savings.
EddieC
EddieC
A retired iron worker that I know has a couple jacks (about his age) that have a very wide wheel track. They look very stable.
Likely not to be found anymore.
West 1
My 2 ton Lincoln has worked for 50 years, I got it used about 25 years ago. Had to install new seals last year when it finally started leaking but after rebuild it is good as new. A perfect old design that keeps on working. I bought it from an old tire shop that went out of business so it has seen heavy use.
I have a Harbor Freight jack, and it has worked fine for me. If/when it starts to fail, off it goes to the dump, and I buy a new jack, probably again from Harbor Freight. They are too cheap to bother with, trying to rebuild, IMO.
mudrunnerz
