Flasher module
greenhornet
Ontario,Canada
Where exactly is the flasher module in a 2015 Tahoe? I have looked and can hear it but cannot locate it.Thanks.
there isn't one, the "clicker" noise is made up by the bcm, the bcm controls all of the flasher functions
what is the problem you are having?
G
greenhornet
Ontario,Canada
I thought that i could change it to stop hyper flash and not use resistors when using LED bulbs. So i guess i will continue to use resistors.Thanks.
STORMIN08
Use a resisted bulb...some have them within the bulb itself.
there are bulbs out there with resistors built in or you can have the bulb-out indicator (hyperflash) programmed out
BlacktopBandit76
