bkboatnsleds
I have an 03 Tahoe - and for a while now my Recirc function has not worked on my HVAC. If you push the button when the A/C is on, it never blew harder or got colder. Also when the fan is OFF, vents were selected to the dash or panel you should be able to cut off ALL airflow coming from the vents if you push the Re-circ button.. Mine didn't do that either.
Everyone complains about the HOT air, and that its the blend door servo - Even the guy at the dealer said, are you sure its not the blend door servo - as thats the common one.
I looked up how to change it on line and came up with squat.. SO I went in and did it with hopes this was my problem.
If you open the glove box, and pull down the door all the way (hold in the 2 tabs on the sides that act as the stop and it will hyper extend.) If you look behind there - you will see a foam looking door behind a plastic grid .. When you oush the RECIRC button that damper should move forward and back. mine didn't.
So to replace...
Take off the passenger side vents (just pop out) - Take off the pass "oh shit handle" if you reach in from the vents you will see a white "button" to hold and the handle just pulls out.
remove all the hex head screws around the top dash panel (2 Phillips on each side where door closes too (driver + pass)
That whole top dash then pulls out.
I took airbag out to make it easier too. (disconnect battery) Un-plug yellow wire and there are a total of 4 bolts , 2 on bottom, and 2 on back.
There are 2 or 3 5.5mm bolts that hold this new servo on. Also keep in mind when you put the new one on - be sure to align the damper shaft into the part, don't twist the servo on the new part at all you will damage it.
See pics for detail
So to replace...
See pics for detail
