Finally got some 6s check it out
1LowHoe
brucebly
Tennessee
Looks good. Does you truck have a lift? I'm looking into getting some rims myself. I have an 02 4wd stock height. What is the biggest size I could put on mine.
Da90
Tulsa, OK
I may be wrong but his looks lowered?
Oklahoma
Deffinantly lowered. The rear end would stick up alot higher if he wasn't. Looks higher because he's rockin 26's with no running boards, and his name is 1lowhoe.
CincinnatiZ
Cincinnati and Miami
yeah its lowered for SURE. Id say he has a 2/3 and those rims are either U2 35's or Giovannas 215's. Wonder if that roll pan is molded in? Either way it looks HOT
1LowHoe
1LowHoe
yes its lowered body mounts are cut out cut springs and torsion keys, yes my roll pan welded in and smoothed. and the rims are velocity
Travieso
Boooooooost !
Los Skandeles, CA
looks very hot bro, do you have any rubbing issues ? did you notice the ride worse with the 26's or 24's irrc you had 24's on it right ?
Modded
That Guy
Looks good.
Funny how it takes a 3/5 on 26s on an 07-Up, to match the height of an NBS with 26s and a 2/3
1LowHoe
1LowHoe
Thanks everyone. the ride was worse with te 24s cause i had the truck dropped 4/10 which was framed and a ruff ride ya theres rubbing up front but thats it.
DwDrummer
AL
Looks good Josh did you buy those from brucebruce?
glazar
