final product looks great homlink buttons
jdub5256
J-DUB
Frederica Delaware
OK so i decided that i wanted all my strobes in my tahoe front n back. the biggest thing was where did i want the switches! I really wanted something that looked completly factory cause after all this is a really nice interior. so i decided to use the homelink buttons in the overhead consule. let me tell you very time consuming and lots of trial and error.
1st i took the overhead down and un did the homelink assembly.
2nd i took the motherboard out.
3rd i found push on push off switches from radio shack small ones with red button
4th installed the switches into the assembly that used to house the mother board
"keep in mind this took roughly 5 hours of trial and error
to get to this stage i ended up having to take the radio shack switches and shaving the push buttons down a little bit so that they could fit behind the homelink buttons
5th went and wired the main hot wire to the switches then and the lead wire to the strobes. and then on the same side as the lead wire to the strobes i ran a wire to 3 leds and installed them in the whole where the indicater light was for the home link. this way its much brighter and white led much cleaner looking.
6th tested everything out and popped it back up in the ceiling and wow awsome results.
I will get some final pics tomorrow but dont have any install pics the girl had the camara.
But let me stress this was very time consuming and took a lot of trial and error but if i was to go do it again i woul prob beable to do it in about 1 hour that cause i learned from my mistakes lol
jdub5256
jdub5256
J-DUB
Frederica Delaware
i install many different kind of strobe and led kits on cars and trucks. this is what i do on the side so i put them on my trucks 1 for the reason i am in the fire dept. 2 for advertisement purposes. it gets alot of attention. so if anyone lives in the de. md. area and you need lights hooked up i can do that for you
bauer4567
Allentown, PA
I just got done installing my strobes. I have two whelen double linz6s mounted inside the back glass, essentially on either side of the third brake light, but inside. then the front is two linz6s flush mounted behind the grill. Noone has noticed them yet, and I dont think they ever will (unless they are on). more importantly though, as far as removing the homelink system... I used a wireless key fob...it looks just like a key fob for your truck, but with an on and off switch. I just leave that in my center console, and can control the lights from inside or outside the car. More importantly, no drilling or routing wires around that beautiful dash... look into it next time...
Scotto2323
NJ
Any photos? What type lights are you using at the bottom of the rear hatch?
Grocery Getter
A guy with a truck.
Phoenix, Az
I can appreciate the mod but can someone tell me why? I get it if like you said your a firefighter and it's a work truck but...........
Don't get me wrong, to each there own. Just curious as to what strobes are used for by the civilian population. My bad if it's a dumb question.
jdub5256
jdub5256
J-DUB
Frederica Delaware
i will have pics in a few days.
i have not been on here in a while but i mostly have them on my truck just cause i make them and sell them so i demonstate them. i am a cop but that does not give me the right to just drive down the street with them on that is still breaking the law. but i will say when changing a tire on the side of the road i deff turn them on because i want to be visable and not get hit.
CKendrick
