Feels like a misfire
Green monster
Toronto, Canada
Ok my Hoe is acking weird the last couple of days. It starts fine and idles normally. Than once it gets to normal temp, It feels like it has a misfire. I'll drive it and everything seems normal than ruff idle returns. I've replaced plugs, wires, air filter and fuel filter a few weeks ago. I checked everything yesturday. Plugs look fine, wires have good connection and are not touching anything. I'm thinking of cleaning EGR and IAC this weekend. Any thoughts what the problem could be? This is driving me crazy, I want my Hoe running smooth again.:emotions122:
fyremanpat
Fyremanpat
if it was a misfire you would get a check engine light. It could be a number of things. Try cheap repairs first. injector cleaner, clean out the TB, seafoam, MAF, etc. Hopefully that will help. Also check your oil for coolant and vise versa.
nimrodcs
Joplin, Missouri
Check your exhaust system too. Dirty EGR, bad O2 sensors, clogged catalytic converters, leak in manifolds. This stuff can cause them to run funny sometimes.
Green monster
Green monster
Toronto, Canada
Ok how do u check MAF? The TB looked clean, I checked that when i did plugs and wires. Ok what is Seafoam, I keep reading about it on the forums, I just never seen or used it.
HotCarl
ID/WA
Seafoam is an additive that cleans out your engine. Costs about $10 at any auto parts store. Put half in through the vaccum line and half in the gas, or you can do it in thirds and put it the oil too. It cleans out the internals of your motor.
Green monster
Green monster
Toronto, Canada
Well planning to clean EGR this weekend(That was my first thought after plugs and wires checked out). I'll try Seafoam in the gas tank as well ( just finished reading tech forum about it. I read that appling Seafoam through vacum line is useless on OBS because it on because Vortec 5.7L only draws vacum from back 2 cylinders). So if I add Seafoam in the gas tank will it still smoke?
HotCarl
ID/WA
It is not useless through the vac, it does clean those two cylinders. I did it today and I had lots of smoke. Putting it in the gasoline won't smoke.
fyremanpat
Fyremanpat
put at least a can and a half in your gas tank..if full..if you only put half a can its would be very diluted. the directions for ounces per gallon are on the can. And for the MAF, get a can of MAF cleaner at the auto store and all you do is pull it of the intake and spray the sensors down like crazy with. let it sit for about 10 minutes and then put it back on
Green monster
Green monster
Toronto, Canada
Well I'm gonna have a fun weekend of Cleaning, EGR, IAC, MAF and Seafoam in the tank. On the plus side, just drove home from work and my Hoe idled pretty smooth. Maybe my Hoe is like me and just hates going to work...LOL
Green monster
Green monster
Toronto, Canada
Well my Hoe is idling normaly again, could it have been bad batch of gas? I filled it up Monday and Tuesday the truck started to run better. Now it's smooth as silk. It just seems strange to me because I've been using Sunoco Ultra 94 fot the last couple of months. I'm still gonna clean the EGR and IAC this weekend(kill some time).
puckhead
CO
Could be your EGR, if a piece of carbon broke loose, it could have held the valve open temporarily then when it got through it would go back to normal. Happened to me a year and a half ago and my mechanic said that. Needed a new battery at the time and he said buy the battery first. Havent messed with the EGR since and its been fine. THinking about deleting it though. You look into that at all?
Green monster
Green monster
Toronto, Canada
I would love to but Ontario Canada has strict emmisions testing now. Even if it would pass the E test it would fail because of the visual inspection. I had a Mustang a few years ago with no cats, air pump gutted and it still blew clean but it failed because the tech seen there was no cats on the car. Government cash grab I F*CKING hate it!!!
puckhead
CO
Dang that sucks bud, glad I live in a small town with no emissions right now! Hope you get it all worked out
Green monster
Green monster
Toronto, Canada
Well I cleaned EGR and IAC today. All I can say is wow, I almost can't tell if my Hoe is running. The EGR was all carboned up and IAC wasn't too bad. This forum is great :) thanks for the help guys.
Candielaine
