feed back noise problem
mikeyboy
freeport new york
i got a extreme case of feed back noise thro all my interior speakers i dont no were to start to find the problem how can i find out if it is a ground or rca if i up plug the alt there is no noise obv cant run like that tho. also if i un plug the rca cable there is no noise eather some times it is worse them others were can i start to find the problem?
Rivieraracing
Have you always had the noise problem or did you do something recently that caused the problem?
dirty runner
I would say start checking your grounds. Do you have an aftermarket amplifier in the truck
Rivieraracing
I'd lean towards a bad ground somewhere, do you have your power wires running with the signal wires?
el_flores
Sounds to me like a ground loop. With that much equipment, it could easily happen. It could be anything from a broken ground shield on rca wires or the components not making a solid ground.
blueflamed03
Oklahoma
agree, sounds like ground, or RCA's, you can start pulling one at a time to see if the noise goes away while system is playing.
Huck
Whut Thee Huck?!
San Diego
I had the same thing. Even with a better ground it didn't go away, so I re ran my RCAs on the other side of the truck, away from the power. Problem solved.
dirty runner
i thought he had already stated that the power was run down one side of the truck and the rca's down the other
blueflamed03
Oklahoma
many others can read this post, other than the OP. Huck added some good info in case anyone esle watching has the same issues.
jwaldo432
Texas
Agreed with others on here, Check your RCA shields, and with the eq there could be a ground loop my audio shop here in texas sells something for it, all you do i plug in your rcas ground the eleminator and run its rcas. If you get alternator feedback when you rev the engine then this is more than likely the problem but not alway. Hope this helps.
JamesinAbilene
