Faded running boards.
chevync
North Carolina
What do you guys use to keep your stock running boards looking like new? I've thought about picking up some black paint and spraying them, i've tried the sprays and none of them last very long.
ArmedArtist
San Diego
I just got my 2004 Tahoe. One owner (mother in law) and I used Mothers Back to Black. It turned all the faded trim to a great look again. Just make sure to wipe the running boards extra good. It could be very slippery otherwise.
chevync
chevync
North Carolina
I don't even step on them, i'm 6'4.lol I would like to take them off but it screws up the lines on the tahoe, once I finish the next two projects up I may just get some straight side skirts and put on it and do away with the steps.
Smasal
Southwest, Mo
Sprayed mine with fusion from wally world. Liked it so much I did the front and rear valances. And the luggage rack.
Sent from my SAMSUNG-SM-N910A using Tapatalk
---------- Post added at 09:39 PM ---------- Previous post was at 09:38 PM ----------
6'4 also. I don't use em either. But my son does, he's 6 years old, and so far it's holding up well.
NathanJax
Vacation Nathan
Jax, Fl
use a heat gun...
[yt]R9tDq1oRy9U[/yt]
[yt]ZQDBTeIObak[/yt]
08grey
Wipe new. As seen on TV. Don't get it on your skin. Lasts a long time.
Have any members used the heatgun method? I'd like to know how it worked both short and long-term.
I just removed one of my running boards and tried the heatgun method. It didn't work on the raised pattern, the area where the raised ovals meet the surface were untouched by the heat and it was leaving white rings around them.
Yeah I stopped just before I melted the damn things! The white rings were still there after it cooled down. I ended up painting them and then the rear bumper covers too with Krylon Fusion satin black. Came out nice, and I heard it wears well.
mwilson62000
Senior Member
Did you guys remove the rear bumper pads to paint or did you just tape off?
I removed all the parts and cleaned them with mineral spirits ( that's what Krylon specifies in the instructions.) The rear bumper main cover is removed by removing the 2 push-in clips that are underneath and then pulling straight back starting from one side. You might have to pry a bit where the clips are with a long thin pry bar. It just has the regular tabs with the spring clips on them. The running board covers and top bumper cover just pull straight up, pry at each clip. Very easy.
Edit: those instructions are for the Denali lower bumper cover.
HeavyHoe03
