Fabtech Lift and Steering stabilizer
GangstaCowboy
Hello-
I have a 98 Yukon with the Fabtech 6 inch lift, and 4wd. I think I am in serious need of a steering dampener with my 35 inch tires. I have looked at a couple kits but it is hard to tell which ones are direct bolt up kits. The Fabtech dampener looks good but seems to be a little pricing. Any real world experience with these or recommendations? I don't want to break the bank on this part, just get something serviceable, I rarely off road. Thanks in advance.
T
bowtiefreak
No Quarter
Near Philly
I'll start by asking why you think you need this. If you say sloppy steering this is not the answer. I have run with and without them and in all honestly I barely noticed the difference
G
GangstaCowboy
I have a bad shimmy in the steering wheel. I have checked over the front end, everything looks good, no loose parts. The steering box looks original so I am sure it is getting worn out. There are no steering issues when driving down the highway, no wandering or shimmy, just at lower speeds over bumps.
Donnie Yukonie
Yates Caretaker
only time i would recomend steering stab, is if your having death wobble issues
G
GangstaCowboy
I had death wobble in my Jeep before, but it was at high speeds. This seems to be at lower speeds and I experience nothing on the highway. I just got done reading about the rag joint, could be my problem. I grabbed the steer shaft and twisted it back and forth, there is definitely play there. Is the rag joint right on top of the steering box? I did not see it when i was checking this morning.
BattelWagun
Chi-Town USA
The rag joint is on the steering shaft itself. There should be a universal joint on one side and the rag joking is that funky looking thing on the other. I know a company makes a replacement billet aluminum u-joint that replaces the rag joint for a little elbow grease and about $70.
G
GangstaCowboy
Which company makes the replacement joint? The rag joint looks like a bad idea.
foreverfalcon40
I recommend on any lifted or lower set-up a steering stabilizer. I am lowered and I am glad I got a single shock one from Sky-Jacker. If I had the choice all over again, I would get the dual shock stabilizer.
I am not sure if this will solve your problems b/c we have two different set-ups. Just a recommendation.
GL!
G
GangstaCowboy
Thanks for the recommendations. I checked the rag joint this morning, it honestly looks tight, no wear. The steering shaft looks pretty clean so I am guessing this has been replaced recently. I am going to try a stabilizer to help with the wobble. If that doesn't work I will just start replacing older parts in the suspension. Does anyone know of a complete poly urethane bushing kit for the front end or do I need to buy them in pieces? I looked around this morning and did not find one. I jacked up the front end and tried jiggling the tires around to see if maybe the joints were loose or the tie rods were bad but I am just not finding anything.
G
GangstaCowboy
Update. Steering stabilizer solved my problems for now. I had a mechanic check out the front and outside of a few bushings being worn he did not find anything major. Wheel bearing boots are rotted and starting to ooze so looks like those are next on the list.
G
GangstaCowboy
I just picked up a Rancho kit from Amazon. Good quality, pretty easy to install. Made a big difference in handling for my truck.
D Rollins
