Exterior Front Door Upper Trim falling off...
DCYukon
Alexandria, VA
Just dropped off my 2015i Yukon Denali at the dealer to see what is going on with both front doors having the exterior trim falling off.
I noticed a whistling sound driving over the weekend and looked in the mirror and saw the trim flapping in the breeze on both sides.
Dealer says that the parts are broken and will have to order new parts, but seems crazy that both sides would just come loose. Anyone else had this issue?
Denton
Waco, Texas
I just dropped my Yukon off this morning for this exact reason. Dealership called me and tells me GM factory bumper-to-bumper warranty will not cover this, and they want $900 to fix it. Im pissed. I am on the phone right now with GM customer service.
DCYukon
DCYukon
Alexandria, VA
Service Rep said mine was under warranty and the parts should be in tomorrow. I will share any paperwork I get back but mine is being covered under warranty...so far.
DCYukon
DCYukon
Alexandria, VA
Paperwork didn't have anything on it other than N/C next to the fix. Dealer replaced at no cost the part and installed it.
barrett20au
Mine did this on the driver's side front window. I figured I'd avoid the dealership hassle and try to fix on my own first. Used some 3M auto tape and haven't had a problem since.
PitBullFan01
NYC
Mine are on order. Dealer said they are covered under my CPO and/or factory warranty. I would suggest sending a PM to GM forum member Brandon. He is very responsive to messages and will usually get back to you within a day. I had a 2nd row DVD screen that was not working on my 2015 Denali which I bought CPO 4 months ago. Did not check the screen when I bought the vehicle. Brandon contacted the dealer and verified the work was done and followed up with me afterwards to make sure I was satisfied. GM customer service was GOOD to me!
Sandy M
Just took mine in for same reason on 10/5/16. It was the back door ones. It was not covered under warranty because I was over the $36,000. They originally wanted to charge me $250 per door. After complaining and speaking with the manager, I got them fixed with only paying $50. I am noticing when I tap them they make a noise. They are coming lose again. And to add to that... my driver side door trim just separated! Calling the manager again to get them fixed. What a hassle. Poor design and poor quality.
hundhaus
Wyckoff NJ
My short Denali is back in again for the same issue. This is the third time my same truck is back in again for this. My Denali XL had the same issue also
cbuckeye20
barrett, I'm having the same issue and looking to repair on my own. Mine are coming off at the top and still feel pretty secure on the bottom
Was there any trick to fully removing the panels or just a matter of slowly pulling away and removing the tape that is left on them?
dmc0926
Alabama
Same issue, replaced 10/25/16 - mine was under warranty also, but this seems to be a common issue.
Aggie76
Warroad, MN
Had it happen to our 2015 Denali XL drivers door last fall and repaired under warranty. Now the passenger side is doing it so will have to call dealer on Monday to get it in. Very disappointed as we've had several other issues with trim, bad paint, plugged drain and then loose hose from Sunroof. The drain hose caused water to come inside next to the microphone twice!
Not a quality product.
Aggie76
Warroad, MN
Visited dealer today. There were two other pieces loose as well it turns out. Dealer replaced all six trim pieces under warranty, took nearly four hours to get all complete.
Kcrowe79
