Engine noise when cold.
rob56
HI TO ALL ONCE AGAIN. ON MY YUCON 03 KNOCKING NOISE FROM ENGINE AND MISSING SOUND FROM tail pipe. once warm its fine.
Physh1
Probably a broken exhaust manifold bolt or two. Common on these trucks. When cold exhuast may leak out from between the manifold & the block. Take a look at your manifolds & see if you notice any bolt heads missing.
Piston slap shouldn't cause a missing sound out of the exhaust. While another common issue, that goes away after a minute or so, it shouldn't be causing the symptoms you've got.
Cameron
boozer
Wichita, ks
Cameron
Piston slap, sounds like **** but normal for the vortec
dizhai
