Engine fan question
iboughtatahoe23
What are you guys say the engine fans being on in 51° weather after almost an hour of driving of stop indoor traffic is normal? I thought they don’t kick on till like 220 or 230?
j91z28d1
are you using defrost or ac compressor on?
if the ac compressor is on, the fans are almost always on.
j91z28d1
OK, cause ac pressure over rider coolent temp.
someone with hptuners can probably show you the fan tables. but I'm sure it's fine
Foggy
KS
Stock fan settings in HP tables kick ON the low speed fans
at about 216. Then High Speed ON at around 224
The problem is that they still keep the low on until
it's around 196 at a small percent. so it has to drop to Zero %
to turn all the way off. I have modified settings.. way better than stock
ALSO: your temp gauge is basically a dummy light
anything from 160-200 shows straight up 210* on your gauge
You'll need a scanner that shows the actual temp to figure out
IF you have any issues in your cooling system.
Double check and triple that your climate system is totally OFF when
diagnosing the fan issue
iboughtatahoe23
iboughtatahoe23
ill keep a closer eye next timee, thanks for that info
im sure its fine... not over heating maybe i did have the air on low bc sometimes air will blow out of the foot well vents even when the system is off. so to stop this, when its warm out i will turn the ac on quick and drop it down to 60 so that way when i shut it off, ill feel a cool draft not a hot one
the 18th letter
Northern New Jersey
My temp gauge only hits 210 if I’m in stop and go traffic on a warm day.
no i dont even think any air was on, jsut was at operating temp (210)
You didn’t mention if the defrost was on. Even in the mixed mode, if the control is set to partial defrost the AC compressor comes on; the system uses it to dry the air out. If the compressor comes on the fans come on. Even in winter mine comes on because the control is always set to defrost or auto and in auto the system defrosts when necessary also.
iboughtatahoe23
iboughtatahoe23
OH IN THE WINTER TO? HUH
(SORRY COMPUTER CAPS LOCKED AT WORK)
CRN_25
