tater
I have a 01 Tahoe LS and i just recently installed a e-fan in it. The wire harness that I used is from Black Bear and i also just got a tune from Justin this past weekend in Pittsburgh. He tuned the pcm for the e-fan that they would turn on at 206 and shut off at 198.
When i hooked up the e-fan yesterday and turned the vehicle on, the right fan came on at full blast and would not shut off until i shut the vehicle off. I checked over all the wiring that i did and i am not sure where i went wrong. i put the blue 42 wire in the correct location along with the positive and negative. Justin showed me where to hook up the green a/c wire and i did that as well.
My question is has this happened to anybody else and if so what did you do to fix it. I think the problem is with the green a/c wire in that i maybe did not hook it up in the right spot.
thanks, jason
thanks, jason
