Dual Battery
99Yuk
Northern Ontario, Canada
Ya that's why I wasn't to go fancy and just wire up the accessories full time off the second batt, not from the IGN.
---------- Post added at 10:58 PM ---------- Previous post was at 10:57 PM ----------
I ended up buying the Surepower 200A relay from www.allbatterysalesandservice.com. When it arrives I'll get a pic and post it.
Dang, that's a fancy gadget. It does everything.
qlc1964
qlc1964
you don't hook the trip wire for the relay the acc you will hook it
up to the wire that gets power only in the run position and thats
the only time it will trigger the relay
R
rdhenderson
Bellingham, WA
I received the battery separator last week while I was out of town. Next on my list is to find a stock switch to mount in the dash near the rear hatch button. Off to the junk yard.
R
rdhenderson
Bellingham, WA
Just finished mounting the separator under the hood. I mounted it upside down so that the polarity of the separator is consistent with how the wires are to be routed.
R
rdhenderson
Bellingham, WA
Grounded the second battery under the CPU using XScorpion hardware.
R
rdhenderson
Bellingham, WA
Finally decided to finish it up after a while off. Decided that due to the type of battery terminals I was using I would do a Big 3 upgrade as well. Used all XScorpion terminals and fittings and Raptor wire. I have attached a few pics. Let me know if you need any other details or pictures.
R
rdhenderson
Bellingham, WA
A few more pictures
PexoA78
