DRL issue
NorCalBryan
Vacaville, CA
Hey all,
I just replaced the passenger side DRL on my Suburban. It worked for about two weeks, and now it's out again. When I knock on the light assembly, it comes back on...It did the same thing before I replaced the bulb, but I thought it was a bad filament.
When I pulled the old bulb out, the plastic around the socket area looked burnt. What is causing the problem here? I assume that it must be fairly common, because on 90% of all 2000-06 Tahoes/Suburbans/Yukons/Sierras/Silverados that I see on the road have at least one of the DRL's burnt out.
What can I do to make them work? I know some will suggest to just pull them out, but I like the look when they're both working.
Suggestions? Thanks in advance.
Narco
Atlanta
are you using a hotter bulb? i just yanked the fuse to mine...i hate the DRLs
steven johnson
wisconsin
voltage spike. replace with led's . why your at it replace all the other lites ( drl,parking,tail , puddle lights, and all inside lamps ) they look a lot better. Hid's for your headlights.
OHSIXX
Milwaukee
Make sure the contacts are clean(both the bulb and socket) and are making good contact.....if not they will get hot and eventually short out ;)
Alex33
Steve has the right idea. It's the voltage spike that keeps killing the bulb. If you're not interested in LEDs, get 4114 bulbs. It's the same size as the bulb there now, but it's rated to a higher voltage so the spike doesn't cause premature wear.
mmeachem
Maybe you got 3157 instead of 4114 bulb
Sent from my iPod touch using Tapatalk
TheYuk
Atlanta
My Yukon kept doing this even with the LED bulbs, ended up having to replace the drl sockets havent had an issue since. Almost every gm dealer keeps them in stock they run about 20 a socket.
mmeachem
Maybe it's a 4114 but a higher wattage check where you bought it from Also do you have a picture of them
A623Z
Phoenix, AZ
Yeah go with leds and a resistor inline with the positive for prolonged life
rbtloe
Cen Cal
I read on another forum that GM for some reason has around 14 volts running to the DRLs that is why they keep burning out also why the socket is burnt, if you put leds in they too will just burn out, because the voltage issue you need to run a 15 ohm resistor to make it the 12 volts necessaryto run your lights without burning out the bulb, the socket, or the housing.
http://www.cadillacforums.com/forums/cadillac-forum/t-109363.html
mfinta
