Driver/Passanger Dome Lights are not working after DL3 Upgrade
Ahmad Al Awadi
Saudi Arabia
Hey,
After the happiness that the DL3 Upgrade worked perfectly, i came to my car in the night and opened the driver door and then i noticed that the Dome Lights are not working!, then i tried the Passenger Door and it doesn't work too!
Even though, The RL and RR Doors and the Lift Gate are working fine, the Dome lights are working once the door/lift gate is open.
BTW: I changed the Master Switch and the Passenger Switch as well, the BCM is alerting the DIC that the Passenger/Driver Door is open but the dome lights do not come on, the issue started once i installed the DL3 & Z75 Mirrors which belongs to the Cadillac.
And i was thinking, does this happened because i plugged the Switches while the doors are open?
In need of your suggestions and support.
Thanks in advance.
QwkSilver
I just had the exact same problem on my dl3 upgrade. Is it only when you open the drivers or both doors?
TallHoe 96 OBS
