door lock problems
Elcaminoguy
just purchased 2000 chevy Tahoe Z71. looks great but having electrical issues. when ever i open any door the horn sounds. can't figured out why. pulled fuse till get some clues... all door locks work fine??
found out this tahoe does not have a bcm......traced problem to fob receiver module which is obsolete. buy used one to test and prove problem is fixed...
S33k3r
Dallas, Texas
Most likely you have a bad wire that is shorting to the horn. Whenever you open a door, power is also applied to the horn circuit, causing it to go off. I'm guessing you might have had an aftermarket alarm on there.
Welcome to the Forum from NH.
Pics of the truck, please.
E
Elcaminoguy
horn is ok now that i removed fab reciever
vsaravia
