Subject: CARCHEX Warranty Coverage
Components Administration Plus Premium Coverage
Seals and Gaskets yes
Wear and Tear yes
Engine Administration Plus Premium Coverage
Engine Block yes
All Engine Internals yes
Engine Cylinder Heads yes
Engine Dip Stick and Filler tube yes
Engine Mounts and Torque Strut yes
Flywheel yes
Intake Manifold yes
Exhaust Manifold yes
Timing Belt yes
Piston Pins yes
Valve Guides and Seats yes
Harmonic Balancer yes
Engine Sensors see contract for exact
Timing Chain Tensioner yes
Valve Springs yes
Vacuum Pump yes
Push Rods yes
Hydraulic and Solid Lifters yes
Timing Gears yes
Oil Pump yes
Piston Rings yes
Distributor Shaft and Housing yes
Transmission Administration Plus Premium Coverage
External Transmission Controllers yes
External Solenoids yes
Transmission Mounts yes
Transmission All Internals yes
Vacuum Modulator yes
Drive Axle Administration Plus Premium Coverage
All Internals yes
Spider Gears yes
Center Support Bearings yes
4 Wheel Drive Locking Hubs yes
Universal Joints yes
Drive Axle Shafts yes
CV Joints yes
Locking Rings and Retainers yes
Electrical Administration Plus Premium Coverage
Distributor yes
Gauges yes
Speed Sensors yes
Wiring Harnesses yes
Coil Pack, Ignition Coil, Electronic Ignition Coil yes
Wheel Sensors yes
Ignition Lock Cylinder and Ignition Switch yes
Instrument Panel Printed Circuit yes
Voltage Regulator yes
Electronic Level Control Compressors yes
Pneumatic Suspension Pumps yes
Keyless Entry System yes
Power Seat Motors yes
Power Sun Roof Motors yes
Convertible Top Motors yes
Computerized Timing Controllers yes
Electric Driver Information Displays yes
Turn Signal Switch yes
Ignition Module yes
Fuel Sending Unit yes
Anti Detonation Sensors yes
Cruise Control Components yes
Power Door Locks yes
Electronic Spark Controllers yes
Brake Switch yes
Hazard Switch yes
Head Lamp Switch yes
Oxygen Sensor optional
Suspension Administration Plus Premium Coverage
Steering Knuckles yes
King Pins and Bushings yes
Spindles and Spindle Supports yes
Leaf Springs yes
Wheel Bearings yes
Ball Joints yes
Control Arm Shafts and Bushings yes
Strut Bar and Bushings yes
MacPherson Struts and Mounts yes
Torsion Bars yes
Coil Springs yes
Radius Bar and Bushings yes
Stabilizer Bar and Bushing yes
Spring Shackles and Shackle bushings yes
Control Arms yes
Steering Administration Plus Premium Coverage
Tie Rods yes
Tie Rod Ends yes
Power Steering Cooler Lines yes
Main and Intermediate Shafts yes
Steering Couplings yes
Power Steering Cooler yes
Pitman Arm yes
Idler Arm yes
Link and Control Valves yes
Pivot Joints yes
Drag Link yes
Power Cylinder Assembly yes
Power Steering Control Valve yes
Air Conditioning Administration Plus Premium Coverage
AC Condenser yes
AC Compressor Clutch Coils and Pulleys yes
Evaporator Core yes
The Accumulator in conjunction with covered repair
Idler Pulley and Bearing yes
AC Compressor Internals yes
Expansion Valve yes
Hi/Low Cut off Switch yes
Temperature Control Programmer yes
Blower Motor yes
Orifice Tube in conjunction with covered repair
HI/LOW pressure lines yeys
Receiver/Dryer yes
Brakes Administration Plus Premium Coverage
Drum Brake Wheel Cylinders yes
Disc Brake Calipers yes
Combination Valve (Proportioning Valve) yes
Vacuum Assist Booster yes
Brake Lines and Hardware yes
Power Assist Booster yes
ABS Components yes
ABS Master Cylinders yes
Cooling System Administration Plus Premium Coverage
Heater Core yes
Thermostat yes
Radiator yes
Heater Control Valve yes
Coolant Fan yes
Fuel Delivery Administration Plus Premium Coverage
Fuel Tank yes
Fuel Pressure Regulator yes
Fuel Injection Pulsators yes
Fuel Lines yes
Emissions Administration Plus Premium Coverage
EGR control valve optional
DISCLAIMER: Information regarding competitor services have been obtained from the websites of actual CARCHEX competitors as of 09/13/2010. CARCHEX makes no representation as to the accuracy of such information.
Wear and Tear yes
Engine Block yes
Flywheel yes
Intake Manifold yes
Timing Belt yes
Piston Pins yes
Valve Springs yes
Vacuum Pump yes
Push Rods yes
Timing Gears yes
Oil Pump yes
Piston Rings yes
All Internals yes
Spider Gears yes
CV Joints yes
Distributor yes
Gauges yes
Speed Sensors yes
Wheel Sensors yes
Ignition Module yes
Brake Switch yes
Hazard Switch yes
Leaf Springs yes
Wheel Bearings yes
Ball Joints yes
Torsion Bars yes
Coil Springs yes
Control Arms yes
Tie Rods yes
Tie Rod Ends yes
Pitman Arm yes
Idler Arm yes
Pivot Joints yes
Drag Link yes
AC Condenser yes
Evaporator Core yes
Expansion Valve yes
Blower Motor yes
Receiver/Dryer yes
ABS Components yes
Heater Core yes
Thermostat yes
Radiator yes
Coolant Fan yes
Fuel Tank yes
Fuel Lines yes
