Busted Knuckles
I've got a 96 Tahoe 4dr. with a heavily used 190k. on the 5.7 .
Pulling over a 2 ton load off road up a 30* slope with no worries . The mileage has dropped drastically (18-19mpg.(after the add-ons below) is now down to 12/14mpg.) I pulled the engine not long after I got the Tahoe March 09' and installed new oil pump , single row roller timing set , gaskets and a major sludge flush . I've got a Fram Washable air filter,MSD. Hot Coil ,MSD 40-50ohm/ft. wires, Bosch Plat +2plugs , alll new O2 sensors , Magna Flow 2 into 1 (2.5"/3") 3.42/Tru-Trac , Good Year Rangler Authority 10 ply tires (run at 75psi.) . The mileage took a crap after the tires . But I noticed this winter at around 0*- -10*f. I heard piston slap for about 2-3 min after start up . At start up , oil pressure is 45-50 psi. ; after it's warm it idles around 25-30psi and on the road runs 45-50 psi. not bad for 190k. .
I've been hearing bad exhaust leaks lately , I found out Tuesday that the Cat. Converter was split away from the rear flange so a Magnaflow S/Steel is on it's way .
I'm considering upgrading the Inj. Spider from the OEM SCPI to the MFI system . Is there any noticeable gains as far as mileage or performance ?
What else am I missing , Cam ? Something mild coming in around 1500-1800
Thanks ,
Steve
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290462830517+&viewitem=
Thanks ,
Steve
