Denali headlight on my yukon
Devilmk4
Sup guys i have the denali headlights on my yukon and am getting tired of looking at the huge gap it has underneath. Is this normal when swapping to this headlights? Is there a way to fix this as is causing my high beam to shoot into the air and i cant adjust them or the side to side. Can anyone chime in on this
Devilmk4
Devilmk4
Sorry about that here they are
Devilmk4
Devilmk4
I can fit a finger under there is like there hanging up
W8TVI
Traverse City, MI
You can't adjust these headlights side to side. There is only up and down adjustments available.
Mind fit something like yours, and I'm able to adjust them up and down so they are aimed properly.
You aim the low beams first, and then the high beams will be aimed correctly. If the high beams are aimed wrong, you might have a bad fit for the bulbs to the retainer ring.
Some of the aftermarket bulb retainer rings are made to allow other bulbs than what the OEM were ment to take, and this can cause problems with some bulbs alignment in the assembly.
This is what mine looked like with the stock grille and Denali headlights:
Here they are with my aftermarket grille:
It still has a bit of gap.
And here is what they are supposed to look like on a Denali/C3 truck:
Ours are never going to look that close.
6speedblazer
hmmm. i put regular Yukon headlights in my Denali and i dont remember any weird gaps. i will have to look when i get home.
Devilmk4
Devilmk4
Here is a better daylight picture. My low beam are aimed good and the high beam hit the tree line on top is crazy and then this gap has me going nuts i feel its a bit to much like the hole headlight is aiming up
inmypassatlife
That's how mine are, no biggie, just aim them correctly and you're done. I have a Morimoto 7.0 retrofit in mine as well and have a perfect cutoff
Mine have that big of a gap too. There are adjusters on them but sometimes the ball-and-socket pops out. Double check that they're solid.
DenaliBQ
check that the pins are in correctly i have had that problem too and the pins were not in properly at the bottom
Devilmk4
Devilmk4
Thanks guys i will double check the pins and the ball socket to see if changes things i want to put led on mu high but being that the aim is off to the sky wont do any justice
Oh yeah, you're talking the mounting pins right? I forgot sometimes you just get them in the top holes and the bottom holes aren't lined up.
DenaliBQ
yes you have to line them up in both holes do the inner ones first then the outer ones
Devilmk4
Devilmk4
I made sure the pins were on correctly and set everything up. High beams still shooting to the sky. I don't change back to the regular headlight cause i don't want to blind anyone with the hid anymore. Also brtween the headlight and retrofit i wont get what i spent on them
BlacktopBandit76
