DEF usage question
Fireman591
Michigan
Hello everyone with the 3.0 Duramax. I have a 2022 Suburban with the Duramax. I just hit 3500 miles on the odometer and still have 3/4 of a tank of DEF. It came with a full tank of DEF when we bought it new in late March. Just wondering if this is normal. We don't do a ton of towing and most of the miles are from driving above 60 mph. Thanks ahead of time.
altona
Parrish FL
I went 4000 miles and was one notch above half. Only 50 miles of towing, 50/50 mix of highway and local 45-55 mph
Matz
I have just under 1200 miles and down only 2 notches. Should make it to an oil change at around 7000-7500 miles.'
Pro299
Sounds about right. I'm at ~13k and have only added three of the Wal-Mart jugs in that time and my gage is only down one bar right now.
Stbentoak
Fully normal, but will dramatically increase if you tow. I’ve put 5 gal in mine at 13k miles and on 1/2 full right now…
suterusu
The first tank of DEF lasts longest, as it is a brand new DPF. But subsequent fills still last 4-5K miles, less if towing.
Stbentoak
DEF has nothing to do with the DPF. It is injected after the DPF and before the SCR....
martinajm
I have put 5 gallons in in about 10k miles or "normal" driving. I had to put another 5 gallons in for a 1200 mi tow (6000 lb boat). Towing drinks the DEF. I was originally told that DEF was proportional to fuel consumption, but it is clearly not...
Stbentoak
CTown Duramax
I suspect that all these "issues" are non-issues.
As I recall, the Euro cars use "Act Blue"/DEF/Urea too.
Tacos
Interesting to see the variances from vehicle to vehicle. I purchased a new Tahoe on November 11th. Started with a full tank of DEF from the dealer. I'm at 2800 miles and have two notches left on the guage.
Stbentoak
Unless you are towing that sounds excessive. I never dumped in my first 2.5 gallon container till about 7500 miles and it was not down to two bars at that point. Overall I’ve got 17,000 miles on mine and I’ve only put in 7 1/2 gallons of DEF total. currently at half full.
BrokerThis
'22 Denali Dmax
Detroit
There are alot of variables that seem to go into the usage. Weather/traffic/driving habits/idle time. Plus it's hard to say if the DEF tank was truly full when you take from the dealer, since there is only the "block meter reading"
I have 9300 mile's on mine. living in metro detroit, so it's remote start winter season. I put in 2.5gal myself around the 7500 mark, and the dealer refilled it during my oil change at the 4000 mark. Currently sitting one bar above half. 95% of my weekly mileage is city driving.
Jellyfrosh
I've been using about 1 gallon per 1000 miles, mostly 70 mph with headwind carrying ~800-1000 pounds of people and cargo. No towing though.
OBSSSD
I got ~ 8500 miles out of my first two def tanks, a little local boat towing here and there mostly highway miles
koomie98
