Decarbing a high mileage yukon
Erik2259271
Bunnell florida
I have a 2001 yukon xl with a 5.3. It has 246k miles on it. It gets pretty bad mileage imo and ive heard from boat guys that mercury power tune wich is basicly like seafoam spray to decarb your engine will help a lot. Im a little concerned that taking all the carbon off quickly like that might be too rough on an older engine so im wondering if anyone else has done this. i just want to make sure it wont do more harm than good. Tia if you can help at all
E
Erik2259271
Bunnell florida
Its a spray that you put into the intake with it running. A lot of people say it works great for everything carburated or fuel injected but i cant find much about people using it on something with a lot of miles
Well, if you are getting poor mileage, start with an additive to clean your fuel injectors. In the old days we hooked up a can of Echlin to our fuel rails and ran the motor off of that until it was empty. Now I just drop a couple of those $.97 bottles of fuel-injector cleaner from Walmart in a full tank of gas. Helped some in my case. Clean throttle plate, MAF, fresh plugs and wires, clean fluids, all contribute to increased and restored efficiency.
Top tier fuels of course garner increased mpgs but more importantly, the detergents in them help keep the parts they come in contact with cleaner.
Is that the same type of spray that goes into the intake?
No, it goes into the oil at about 1000 miles before the next scheduled change and into the fuel. I have some but haven't put it in yet. There's been alot of people here who have used it, with amazing results as far as cleaning the engine. Look into it, there's threads on here and lots of testimonials on the web.
BlueCollarTahoe
isnt that kreen a penetrating oil? got any links to the stuff? im willing to try this. i Just put a can of BG44K into the gas tank see how that goes. my MPG sucks.
RED TAHOE LS
Rossville, Georgia USA
In earlier years, before the 350 cu in was even thought of, engines were higher compression NON FI (EXCEPT CORVETTE) and carbon was a real problem. GM made a pint can of TOP ENGINE CLEANER that was poured slowly in the carb @ 2,000 rpm until the engine began to stall, then you dumped the can to stall the engine. The car would be left OFF for a couple of hours to soak. This would loosen carbon and when started would smoke up the area but would correct any build up and knocking sound. I'm sure GM has a similar product.
David g...........:2cents:
Nashoba
South Central Oklahoma
There are many good videos on youtube that deal with cleaning the engine. Just go there and do a search for SeaFoam or Berryman's B-12 injector cleaner or some such language. There are even some tests comparing five or six brands of this type engine cleaning. I have stuck with Berryman's myself. Plus I don't get gas that has Ethanol in it. I just don't like that crap.
Steam clean that ish!
The trick is to not flood the engine with water (I'd use a spray bottle for misting) and there's a chance that the released carbon particles can get lodged in the catalytic converter and clog it. Proceed at your own risk. There are gentler methods that use chemical additives to dissolve the carbon over time , but it's over a very long time.
I know water works because I had a cracked head on a Jeep 4.0 that dripped water into a cylinder. That #4 piston and combustion chamber was CLEAN. I don't have the pic handy, but here's one off the interwebz that's a close example:
carluvar
Indianapolis
Nothing I repeat nothing will clean the stuff coating the inside of your plastic intake so fugetta bout it! Bg 44k is the best injector cleaner use it! and look at fuel trims on a scan tool and maybe get a set of new injectors, they all need to flow the same. If they dont, youll end up with some lean and some normal running cylinders, the computer cant control injectors individually. WHEW!
BlueCollarTahoe
anyone got a link that shows the use of kreen clearly? found a bunch fo grainy before and after vids cylinder by cylinder
rockola1971
Indiana (formerly IL)
Water, its practically free and will clean the hell out of combustion chamber, valve heads and faces and piston crowns. Ever seen a piston after a blown head gasket lets coolant in the cylinder? The piston is always factory new looking with all carbon gone.
The water doesnt steam clean the piston. The water temp is way colder than the face of the piston and it causes rapid contraction then expansion when the water contacts the carbon which causes the carbon to just pop off and get expelled into your exhaust. Too much carbon on the crown of your piston causes the dome or the recess to gain in volume which INCREASES your compression ratio and if the fuel you are using doesnt have high enough octane rating that can lead to detonation (spark knock). It will reduce efficiency along with MPG. Water is practically free! Transmission fluid in your gas tank WILL clean the hell out of your injectors and its way more effective than most tank additive gimmicks too. This trick has been around for many decades before I came about in 1971. Many old men taught me alot before they left us all. I listened and still do.
BlacktopBandit76
