Cruise Control
elsamurai
In the general course of troubleshooting non-function cruise control, what is step 2? I replaced the brake light switch this weekend to no effect. Do I look at replacing the stalk/switch next or the cruise control module?
elsamurai
elsamurai
You assume correctly. I suppose I need to ask what step 3 is...
Rockytfox
What year/model do you have? Have you visually checked for burnt/meted insulation and/or wires? Have you checked voltage yet?
noJeepshere
Bountyfull, Utahrd
Double check the connection at the VSS, make sure there are no abs codes, and the multi-function lever on these are known to go bad.
elsamurai
elsamurai
99 Yukon
skipping ahead to step #134, it does not function at all. the turn signals/high beams all work at the stalk.
where is/what does the control module look like? do the stalks still pop out when you push in and turn?
retorq
Kingman AZ
Does your gear selector on the cluster work?? I know mine doesn't and neither does cruise ...
elsamurai
elsamurai
yep. best guess is the switch on the stalk. i will probably try to replace that next.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
under hood to the left of booster on the firewall is a black box with a throttle cable coming out of it. everything is in that box.
sdp9427
