Cruise control not working
DStockton
My cruise control quit working. The button to turn it on is lighting up on the steering wheel but it doesn't light up on the dash and won't work. It was working every once in awhile and now it won't at all. This is on a Denali. Any ideas?
DWray20
Cochranville PA
What year is your Denali? My 08 Sierra has been doing the same thing. I found when I pull up on my break pedal I usually can get it to work, but not everytime. Not a fix but a trick you can try. And maybe a direction to look into.
onelovechicago
check your break lights. any of the bulbs burnt out? most common cause for the cruise control error
NathanJax
Vacation Nathan
Administrator
Jax, Fl
x2
also, do you by chance have LED tail lights? That will do it too if the right resistors aren't there...
D
DStockton
All lights in tails are working and they are factory tail lights
AZSCTACO
Phoenix, AZ
Mine starting doing that 6 months ago....I would kick the brake pedal to get it to start working again. Finally got so bad I replaced the sensor that is connected to the brake pedal and it works like a champ now. Part is like $11 att eh dealership and you can replace it yourself.
See thread below - It's called (I think) Brakelight Switch when you go to the parts dept.
http://www.tahoeyukonforum.com/forum/showthread.php?t=27481
D
DStockton
Do u know the part number? The dealer is trying to.charge me $40.
AZSCTACO
Phoenix, AZ
http://www.amazon.com/ACDelco-D1539J-Stop-Switch-Assembly/dp/B001KSGJKQ
---------- Post added at 10:39 AM ---------- Previous post was at 10:38 AM ----------
Mine did it too...it is the switch in the brake pedal.
It's mounted between your brake pedal and the firewall....once you get under the dash, you'll see it once you have the new one in your hand
---------- Post added at 10:41 AM ---------- Previous post was at 10:39 AM ----------
Looks like this
As an Amazon Associate we earn from qualifying purchases.
eodcoduto
