Couple questions 2000 obs z71
dub02gpgt
dub
WI
Hello All,
I'm currently in the process of looking at a 2000 z71 that has a couple of quirks. The vehicle has been in a front end collision and has been repaired. I would be buying it from the person who had the repairs done(a family member) and i noticed when i drove it that the airbag light on the dash was on? i asked about it and they have plugged it into two scanners and not found anything and it seems that the light comes and goes at will for no reason. Anyone have any idea what to look for or why? Also, the gas gauge seems to flutter when going down the road... i wouldn't say it wildly swings from E to F but it moves quite a bit considering how they normally operate. Otherwise it has fairly new tires, brake components, plugs, wires, cap distributor, intake gaskets about a year or so ago and some new body parts up front. It does have scratches but all 10 year old vehicles do and it needs balljoints, pitman arm, and idler arms and then alignment. Without prior damage considering these are going for over $7200 and the nearest vehicle i have seen are at 6500 and 6995. i think i would be getting this one around 5-5500. Needs a full detail and possibly a whole new carpet(grease and oil stains). Just want to get some opinions from you guys.
Thanks for reading this overwinded story...
AtomicHoe094
Atomichoe094
cleveland, OH
Not sure on the bags. doubt anything is wrong wrong with it, it probably didnt get hit hard enough for them to deploy
Gas gauge- give me some more on that. what do mean swings? from getting off the line to braking? or always swinging?
not a bad price. shoot some pics and itll help me out. make sure your front end body panels are aligned..
TahoeGoBoom
blue interior guy
I wouldnt pay 5k for an OBS. retail on mine is 8k, stealership wanted 7k, walked out with it for 4200 tax tag title out the door. it only had 103k when i got her in mint condition. and mines a 99. i think z71s and limiteds are over rated. i did find a limited local tho. they want 6k. with 180k on the clock. can you say new tranny?
D
dub02gpgt
dub
WI
the gauge is always moving like a 1/4" to either side at any speed it seemed to be just keeps moving. I don't believe the bags were deployed, but not 100% sure. this truck has around 138 on it and there are three other almost identical trucks for 7200, 7895, and i think 7995 same options and color and year mileage from 116-160ish so this one is far below those and the panels all look good. it has a cowl hood too. i just want everything to work on it. there is a 99lt with 95k for 6995 and a 99lt with 141on body and 13 on jasper replacement motor with a bunch of other little things taken care of for 6500. anywhere around me for a 98-2000 with leather is over 6000 or it's shit. i've been looking around craigslist and autotrader cars.com and even ebay. maybe i'm just to picky
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
My dad's 1999 Suburban's gas gauge flutters back and forth all the time too. Did it before we did the fuel pump and after. I think it's normal on these trucks. That and the oil pressure gauge drops when you brake. Nothing wrong with the oil pressure, just dips down when slowing down. I wouldn't look too far into it.
96ProCompTahoe
IN
its either the sending unit in the tank, or like most, the guage itself. you can pop one of the little motors out of another cluster and put it in yours. problem solved.
AtomicHoe094
Atomichoe094
cleveland, OH
Thats what my escalade guage was doing when i did the swap, i changed the actual gauge and it works perfectly now. i took off the needle and aligned it perfectly so once i hit E i am empty.. i didnt like the fact where it could go past E with still gas in it
Effeckt
Resident Cards Fan
Phoenix, AZ
Fuel gauge is a normal issue on these trucks. My dad had it on his 00 Suburban, a friend of mine has it on his 04, and I have it on my 01. Mine will read accurate for the most part while driving but drop occasionally and drop constantly when stopped or in park. Not sure on the airbag portion of it. If that is your only 2 concerns and you can get it for 5 I say go for it.
AdrienR
