Coolant leak - Line from AC compressor to radiator?
rfried
Southern California
2004 Yukon - 185,000 miles. Original hoses.
Need help figuring out what hose I have that's leaking. I've scoured this forum, my Haynes manual, and the internet for over an hour so I'll just ask.
Look like I have a coolant leak (its red, doesn't smell like trans) that's weeping from a metal end of a black hose that goes from the radiator (to the right of the main large radiator hoses) into what I think is the AC compressor (I say this because the large hose from the condenser enters the engine next to this hose). Does anyone have an idea what this hose is called so I can pick one up and the best way to change it out?
I appreciate any and all help.
R
rfried
Southern California
Update
The line that is leaking is the AC discharge hose, going from the compressor to what I believe is the heat exchanger. Look like just a few bolts and replace. Does anyone have a link to do this to make sure I'm not missing anything?
01SLE
I might be reading this wrong and way off base here but it almost sounds like you're describing the power steering line (and power steering fluid is typically red). Can you post a picture?
R
rfried
Southern California
After researching it is the AC discharge hose as shown. It is leaking a red fluid from the metal coupling in the middle. The fluid def isn't coolant, it's slightly oily but has no smell like trains or PS fluid. The line does go to the condenser in front of the radiator.
j_jerry79
