this is basically everything you need, great deal for the set, I have not heard any complaints, I guess it can really depend on what your looking to do and how much you want to spend.Looking to upgrade everything front end suspension wise, what all will I need and who’s the best company to use? It’s. 2005’ 2wd Tahoe 5.3
This is relative. While you already are doing this, do you want to change your height? Do you want a firmer better handling ride? Do you want to upgrade for the long term? Are you on a budget?Looking to upgrade everything front end suspension wise, what all will I need and who’s the best company to use? It’s. 2005’ 2wd Tahoe 5.3
I will speak from experience with both moog /ac delco parts and the cheap all in one kit.
I got a cheap all in one set from 1aauto for my Tahoe and had to replace tierods in about 6-9 months.
On my Denali I got all moog and ac delco parts along with tbss drop kit and new wheel hubs
The quality in parts is absolutely noticeable but so is the price. I spent upwards to 1500 on my Denali overhaul vs about 200 on the Tahoe. But the yukon is a much better ride and I dropped it and swapped shocks
Ive always looked at it as; With anything automotive, you are probably paying twice as much for a 10% better product, but that 10% could mean the difference between quick junk and a lifetime.
Right!.... I think. Anyways I go for the tried and true. I'm not doing an all in 1 kit for 150ish it's not worth it to me knowing I'll have to do the job again.. I remember what the 1aauto parts looked like and when I got the moog and ac delco parts I had to double check to make sure I got the right parts and not parts for a HD truck or something. The quality and weight were night and day. I feel much more confident driving this stuff than the cheaper stuff
I’m going to go with the moog, would you guys suggest getting the complete Control arms or just get the kit and replace ball joints etc..?
Can't say I recommend moog. Put them on my car. Took 20k miles to "break in"
Inner, outer ball joints, pitman arm, idler arm, and bracket. The stuff was so tight from the factory it was giving me all sorts of weird steering phenomena. No/little return to center, bump steer when there was a little bit of pressure on the steering wheel and the components flexed, memory steer, and overall a bit of a dog to steer on the freeway - couldn't just guide the wheel, I had to crank it a bit to get enough tension in the components to move. Then they'd stay more or less stuck in that position until I had to make my next correction.
Installed them at 114k. Now it drives as expected at 138k
Problem solver. Purchased Oct '16 from rock autoInteresting. I didn't have any of those issues with my moog parts did you go with problem solvers? Or another moog line up?
FWIW I noticed a small improvement when I switched from the bulk grease I had laying around to a quality, high moly chassis grease.
Currently using Amsoil Synthetic Polymeric Off-Road Grease, NLGI #2, Other greases will perform well, this is just the one I'm using.
It's offered in 2 viscosities. #1 and #2. #2 is what you'd typically associate with grease, about like peanut butter. #1 is thinner and more suitable for things like wheel bearings, or u joints - things that move at higher speed.
While on the subject of grease... Be mindful of what you use on your undercarriage. Lithium soap type grease washes out fairly easily.
