Code P06DD thrust bearing issue...
Stbentoak
Stbentoak
Well this sucks after buying a 100k vehicle and putting another 12k in it. I too bought diesel to avoid the 6.2 issues.
No issues so far after 1400 miles. Are people taking them in proactively to check?
I'm not. You either have it, or you don't. If you do, it will evidence itself. If you don't, you will have to pay for the evaluation.
I wonder what they would do if you have the problem, but it's still running well?
DuraYuk
... and people here said that the baby Duramaxes were the more reliable GM engines...
... what is wrong with GM these days?
They still are and nothing is wrong. These problems have existed since the dawn of man.
You guys just dont have very long memories.
Ive been there and done that. Its just part of making things. Shit can go wrong otherwise nothing would come with a warranty
DuraYuk
If its out of specification it will throw a code. No way you have an issue without driveability problems or codes. The tolerance is way loose compared to what it needs to be.
Siginsde
Well based on mine and other LM2's... It has been rock solid for 40K+ miles. LZ0 was supposed to be an improvement over LM2 but not with components that are not up to par for the job.
I am at the same mileage you are on my 25. So far so good.... But I'm nervous. I don't have a lot of faith in a dealer fix for this issue or having an engine replacement. Both of them are heavy issues that usually don't turn out well. Fingers crossed that mine is one of the good ones. I count on this vehicle every day and don't have a backup plan......
I hope your are good also, I bought this for a family car my wife is literally due with our 3rd child next week. I already looked in Lemon Laws, unfortunately South Carolina is pretty vague. It states "it needs multiple attemps at repair and in op for 30+ days.
I work on the lending side of the auto industry and everyone is saying the car business is dying. It's because customers do not have any faith in what they are buying, and the manufacturer is charging entirely too much. I thought I was doing the right thing by going with the Duramax but I'm sick to my stomach now.
blanchard7684
Senior Member
Do not try to switch between gas engine oil and diesel formulas with a direct injection system.
DuraYuk
Why are you sick? Dude get off the forums. It will do this to every make and every brand. Just enjoy the car. You have warranty.
Ive bought hundreds of cars and every single one is full of forums with tons of issues and I've experienced less than 1%.
I worked for GM during the golden years and I was fixing transmission after transmission all day everyday. Fixing timing chains, lifters. But today those forums are touting how reliable they were. Guess i was dreaming ? Lmao. Bought 3 homes with all the 4l60e and 6l80 rebuilds. With all the 5.3 lifters. With all the 3.6 timing chains.
Relax.
Stbentoak
Stbentoak
Do you believe if these are bad... they will go bad fairly quickly? Say 5 k miles or less? Seems like if it was bad out of the gate.. you won't make it 1000 miles....
Jayhawkeye3
How loud of a knocking should you be looking for? Diesels naturally have a bit of a knock/tic.
Stbentoak
Stbentoak
Listen to this and you will get it.....
DuraYuk
Yes they will go bad early. Its a mis spec thrust bearing. It wont last being out of tolerance. Its gonna chew up quick. Extra oil changes won't help. You either have a spec part or not. And if not its chewing up quick. Id imagine you make it to 10k miles your safe.
Yeah I bet you hear noises (most may not notice because most people dont pay attention) followed by code....followed by catastrophic failure if you keep ignoring.
First symptom is noise by bell housing. Then code. But for most people the code will be the first indicator.
Im not here to make people feel safe. But as a former gm heavy line tech. A toyota fan (i love reliability). My wife being the primary driver with my kids. Im not worried. Until it shows up if it does. And when it does i will have my friends who still work for gm fix it. And I will continue to love it. Because it's amazing. So amazing that this is the 2nd new one we bought.
Don't sour your grapes unless you need to.
Just look at the 6.2 fiasco. This isnt nearly as common. And im looking everyday to change my mind. And havent yet.
DuraYuk
Its a metal clang. I promise if its doing it you wont be able to ignore it. Its evident. It sounds like a broken flex plate.
Jayhawkeye3
Any more news on this topic? So far so good for me. Although I only have 1800 miles…
Siginsde
My engine failed at 3250 and has been up at the dealership for 3 weeks. The dealer originally told me they were going to replace an oil pump and turbo I had to get General Motors involved to get them to look at the tsb. They finally measured the crankshaft and determined an I needed a new engine. They ordered me a new one, No eta on part arrival all. I have a case number with GM and hopefully things will get worked out sooner than later. My trim was a Denali I don’t know if certain trims are affected or just build dates.
Stbentoak
Stbentoak
It would really be interesting to know what the prevalence of this problem is. Is it one out of every 3000 vehicles?, one out of every 10,000 vehicles. Or a series of vehicles within a certain month or so of manufacturing range that had defective parts? Or in the big world, is this just something not to worry about until by chance lightning strikes you?
Siginsde
I work In the auto industry and mostly all of the people I have spoken with do not know about this issue. I actually joined this forum because I saw this thread when I was researching the issues my vehicles were having. Without a lot of people knowing it I was thinking that’s a good sign, and take it for what it’s worth it’s Murphys Law for me. I wouldn’t worry about anything until it actually happens.
DuraYuk
8900miles 2025 at4 xl LZ0 going strong still..
Former Gm tech.
Toyota fan..
Wife's primary car.
Still love it and not scared. If it breaks it has a warranty and nothing comes close to size, efficiency, etc. So no replacement id ever consider even crosses my mind.
DuraYuk
Hey guys just an update.
2025 GMC YUKON XL AT4 LZ0
Guess what? Hit 10,000 and it hasnt blown up.
Yay.
Not worried. Love it. Been getting about 28mpg at 79mph. Love love super cruise. .makes road trips a breeze.
Carry on.
Scarey
Having oil changed at dealership. Talking to them it sounds like thrust bearing is becoming a big deal, they have two in the shop now with failed bearing. Gm is really becoming a shit show.
DuraYuk
Gm has always been a shit show. Now you have the internet. Only difference.
Flathead40
Yay.
Carry on.
Our XL AT4 is at 14k and so far so good. Seems like this is more isolated than a widespread issue.
MoundMedic7
