Code p0172 and p0175
HiHoeSilver
Away!
Chicago
I am going to do a pressure test this weekend. The guy I bought it from said he changed the fuel pump but that doesnt mean it couldn't go. Also my fuel gauge is messed up. It went way pass full and is at the bottom. Thank you for all the help.
I don't know how much help I'm actually being, but it's fun none the less!
V
vertical99
Well I broke down and took it to a local mechanic that a guy from work knew and he said it was the ignition timing. He said with an older truck with high miles the timing chain gets stretched out and the computer has to relearn the timing so He hooked up his computer and ten minutes later it was all better.
Now that's a new one for me...:eek:
SnowDrifter
Sasquatch Country
Same
Ignition timing on these is electrically variable. If your chain is that stretched, I'd be more concerned about the thing skipping a tooth. That's a lot of fuggin' slack on a small chain.
To my knowledge, these don't even have a relearn for that. Sounds like something got lost in translation
Either way, glad you have it resolved!
dizhai
