Climate Control Temp Display
jrdecat
coloRADo
I have a 2003 Yukon XL SLT with the digital climate control display. As I turn the knob to change the temperature the numbers are very sporadic.
For example: temp is set on 60 and I want to switch to heat. As I turn the knob clockwise the display goes 60-61-62-63-62-63-62-63-64-65-66-64-65-64-65....and so on.
It does this in both directions, whether I'm increasing or decreasing temperature.
Just curious if anyone else has this problem. It's not like the HVAC doesn't function...this is just mildly annoying.
Bear77
South FL
x2 for the mildly annoying!
jrdecat
jrdecat
coloRADo
So....any ideas whey they do this? Is the fix to buy a new HVAC control module?
SC
Mine does that too. If I push in on the knob a little and turn slow I can usually get to the desired temp without much jumping around
Laurents10
